Dayton 3e289 heater
Lighting the pilot
jeffk14
  • 16 Answers
SOURCE: I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Posted on Nov 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: pilot light goes out when turning on the thermostat
Check your thermocoupling to make sure that it is sensing flame. You can tell if it is good or bad by the white on the tip of the flame sensor. The other problem would be a blocked or closed flue pipe. Make sure that the cap is not smashed down on the pipe on your roof
Posted on Feb 13, 2009
clyde2j2
  • 137 Answers
SOURCE: Dayton Furnace - Pilot Light Goes Out but Fan keeps running?
Pilot lighted furnaces have a thermocouple made from disasimilar metals that when heated create electricity to actuate a relay that alows the gas to flow to the furnace.
When the thermocouple gets coated with carbon from the pilot lights constant burning it acts as an insulator and keeps the thermocouple from getting enough heat to generate electricity, a very good safety factor.
What you have to do is locate the thermocouple it should be located over the pilot light, you will see a gray substance around the thermocouple it will be hard like cement, take a knife and scrape away as much of the gray material as possible then sand the themocouple with a medium sandpaper until it shines, use one of you wifes emery boards, this should solve your problem.
Posted on Feb 24, 2009
  • 340 Answers
SOURCE: pilot light keeps going out! difficulty lighting
Dirty pilot, you may need a contractor.Tom
Posted on Jun 18, 2009
  • 24 Answers
SOURCE: have dayton heater,model #4LX41A heater comes
try cleaning the thermocouple or even replacing it because if the thermocoulple doens't sense the pilot light then it won't open the gas valve.
Posted on Jan 24, 2010
Pilot light on my heater keeps going out an I have a hard time lighting it. It's a Royal Jet serial no. Is 55FG385412 Model FG355 help if u can
Get the pilot light sensor replaced as the burn down with use and if they are just out of spec the sensor cools and shuts off the gas flow for safety
Dec 05, 2015 | Dayton Gas Furnace Heater
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Have Dayton 3e227a gas heater fan has quit, need new motor, can you supply source to buy? Tim
Dayton is a Graingers Brand. Go to the site below and I'm sure you can find your part. Put in your Part Number...Jim
http://www.grainger.com/Grainger/rp_parts_home.jsp
Feb 18, 2011 | Dayton (3E227) Gas Radiator Heater
Have dayton heater,model #4LX41A heater comes on,pilot lights but no gas ignition ? Already cleaned injectors, and made sure i have gas. Mike M.
Jan 24, 2010 | Dayton (4LX41) Heater
Why does a pilot light go out,but the fan keeps running?
some heaters use a timer to bring fan on as opposed to some which use temp
Feb 24, 2009 | Dayton (4LX41) Heater
Dayton 3e239e looking for operation manual
Normally you turn the gas valve to the pilot position, light the pilot, hold down the gas valve knob for 30-40 seconds and release. If the pilot will not stay lit replace the thermocouple. These are available ay Home Depot.
Ray
Dec 06, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
