Question about GE 27928GE2 Cordless Phone
Message box full-cannot cleat - GE 27928GE2 Cordless Phone
  • 39 Answers
On most GE 27***GE-series phones the DELETE key on the base is to the left of the down arrow for MESSAGES/CID keys; the DELETE button is the button on the far left on the bottom row of tiny keys.
Press the button briefly during play-back to delete the message being played, or press and hold the delete button for a full 2 to 4 seconds to clear ALL messages.
Posted on May 22, 2014
How to get a nice shoe
  1. Choose a Football shoes based on your playing position.
  2. Buy football shoes with molded cleats if you consistently play on the same field or the same type of field.
  3. Purchase football shoes with detachable cleats for versatility if you travel to, and play on, a variety of field types.
  4. Get shoes with cleats that are 1 inch (2.54 cm) long if you generally play on muddy fields.
  5. Use half-inch (1.27 cm) cleats for the best traction on hard-packed, natural grass.
  6. Buy football shoes with numerous tiny nubs on the bottom for the best traction on dry, artificial grass.
  7. Wear football shoes made from leather for increased flexibility and to help your feet breathe easier.
  8. Purchase shoes made from synthetic materials if you need extra support or reinforcement in the ankle, mid-foot and forefoot regions.
Jul 04, 2016 | Nike Youth CR7 Mercurial Vapor VIII FG...
Doesn't fire full pressure
Set your compressor at a higher psi. Maybe you need a better compressor
Oct 26, 2013 | Porter Cable 2" Flooring Cleat Nailer...
What is the difference between rugby boots and soccer cleats?
My rugby boots are heavier and sturdier than my soccer cleats. Depending on the position you play, some of the boots go higher up the ankle instead of soccer cleats that cut off just below it. Also, rugby boots have around 10 studs whereas soccer cleats have about 16, give or take.
Feb 06, 2013 | Rugby
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I have a central pheumatic stapler model 99640. When I used it, it shot out 2 'L' shape cleat (16G, 2") at the same time instead of 1 cleat. I tried to minimize the gap for the mouth, it end up jamed....
I have noticed that some nailers with this problem have a driver blade that is slightly wider than the width of the cleat thus allowing the driver to actually hit part of the second cleat in the strip. To fix problem the driver blade should be slightly trimmed or tapered. File/grind the driver only on the side facing the cleats. Remove only enough metal to allow driver to hit only one cleat. Taper the grind up about 1/2 inch. This tapering is used on many different drivers including fraiming nailers to prevent the driver from hitting second nail on strip (mainly clip head nails). Only other remedy is to find thicker guage cleats that will still fit thru nose. Good luck with your repair
Oct 08, 2010 | Craftsman Air Tools & Compressors
Can't fit the cleats to MO76 shoes. Instruction
assuming your using Shimano pedal cleats?
You should have on the bottom of the shoe 4 threaded holes showing.
(if not then you will need to check the shoe box as sometimes they need to be fitted)
The cleat should be placed directly on top of this... with the point facing towards the front of the shoe.
You then need to place the OO plate on top of the cleat and place the crews in making sure the cleat is positioned straight.
Once tightened then place the cleat on the pedal and make sure its position is correct and your shoe is sitting straight then re-tighten.
hope this helps.
p.s. try here http://drivemybike.wordpress.com/2009/05/23/understanding-clipless-pedals-installing-cleats-on-shoes/
Feb 26, 2010 | Shimano Cycling
I am not able to send sms from my mobile
Check your message settings such that message center in use. call to your customer care and ask for message center number and filled in the proper place.. switch off and switch on your mobile... This will get cleat...Hope you will succeed...
Dec 22, 2009 | HTC P3470 Cellular Phone
Always display message full although no message
if your mobile memory is full. it shows message box is full so pls check your memory in phone.and memory capacity in your mobile
Sep 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
GE 27928GE2 Cordless Phone Logo
98 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
