Question about DSC Wt5500 Alexor Wireless Lcd Keypad 2-way
Dsc wt5500 blank screen
Changed the batteries no screen still
My DSC Wt5500 Alexor Wireless keypad not keeping correct time even after changing batteries. Is there something in the programming I need to do to get it right? Thanks!
I am assuming that the keypad was successfully enrolled? Try to reprogram time. Time should be coming from the main unit and not the keypad itself.
*6
Master Code
24 hour time (ie 2pm= 1400)
Date Format mm/dd/yy
Keypad should confirm successful entry by beeping rapidly three times
press # a couple times to get out of programming
After exiting programming the display should come up within 30 seconds or so displaying the date and time before it goes back to sleep.
Apr 12, 2015 | DSC Wt5500 - Alexor 2-way Wireless Lcd...
How do you change the battery?
you need to change the battery in your main control panel, the keypad does not have a battery installed. somewhere you should have a white metal box installed, open the box and you will see a black battery. remove it and take it with as a sample. be sure to check your power supply as low battery normally means that the battery is not recieving power to charge. take a multimeter and test the voltage before changing the battery.
Oct 02, 2013 | DSC WT5500DMK Desk Mount and Power Supply...
Viewing Screen Blank Put new batteries in but no change
Make sure the lcd is turned on. usually have a button on unit labeled lcd/viewfinder.
Mar 30, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony DSC-W5 camera and the LCD screen is blank (white)
Remove the Battery pack from the Camera then press and hold the power button for 30 seconds.
Next, reinsert the Battery pack in the Camera and try to turn it ON. Make sure that the Battery pack is fully charged. If the LCD remains white then the LCD screen needs to be serviced or replaced.
Nov 25, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
TURN CAMERA ON SCREEN FLASHES cYBER-sHOT AND GOES
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 08, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank white screen sony DSC t77
To Power Reset the Camera, please remove the Battery from the Camera, press and hold the Power button for 30 seconds and then reinsert the Battery.
Another option: I took the battery out and I pressed Menu and Shutter button for 30 seconds and it worked! The screen is back!
Jan 05, 2009 | Sony DSC-T7 Digital Camera
Blank LCD
Camera of this type are not usually repairable.
No Parts.
Like toasters/ kettles etc they are considered 'disposable'
But don't take my word for it - check out the makers support page
Jun 03, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Sony DSC-P200 blank screen
maybe you must go to the repair shop for this problem. its very dangerous for us to fix it with our self.. because it might cause more problem.. thanks!! nick_004
Mar 04, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
DSC Wt5500 Alexor Wireless Lcd Keypad 2-way Logo
60 people viewed this question
Top DSC Home Security Experts
yobo007
yobo007
Jerry Kramer
Jerry Kramer
Terry Weaver
Terry Weaver
Are you a DSC Home Security Expert? Answer questions, earn points and help others
