Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
Need a part for Pegasus toilet part is Fluidmaster 703 valve C2216-9
Part of Fluidmaster is missing, must have flushed off--- now water sprays everywhere and toilet does not flush effectively, emptys but paper and ***** left in toilet! Do I need the complete Fluidmaster or just a part that fits on it??? DESPERATE---pouring buckets of water down toilet to enable us to use it!!! HELP!! Thanks~
Fluidmaster
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
Im a woman so i dont know much about this stuff but my toilet bowl wont refill and i need to know what to do... i have a fluidmaster 200a
Take off the cover and look at the mechanism when you flush. It's possible the set screw that keeps the flush rod in place has just loosened. If not then the easiest way to deal with this is to replace the Toilet Refill Valve. Turn the water line at the base of the toilet to off. Flush until most of the water is out of the tank, the go to Home Depot and buy this:
Fluidmaster Toilet Tank Fill Valve 200AX The Home Depot
Unscrew the old one and screw in the new one.
May 03, 2015 | Home
Why does the toilet make so much noise filling FluidMaster 703A5B
Just replace the flush valve with another one.
Flush the water line by opening valve before attaching new flush valve
Aug 07, 2014 | Fluidmaster 507C White Flush Valve
When flush my toilet, water keep running until i put my hand inside the middle and pull the float , then stop. toilet make is rapid sl
the ball **** fill valve is a poorly designed valve. replace it with a fluidmaster fill valve and a fluidmaster flapper. flappers do go bad after a year or ten depending on your water quality and choice of flapper but the fluidmaster fill valve will last a long time also. you can also get the water saver fill valve by fluidmaster and there is also a conversion set to change your toilet to a dual flush. all this is at lowes and there is a plumbing pro there to explain further. feel free to give me a positive rating. thanks!
Feb 15, 2011 | Home
I have fluidmaster in my mancesa toilet. After flushing the toilet tank doesn't refill unless I turn off the water supply and turn it back on. What do I do to fix this problem. Wayne
First thing to do is figure out if the problem is with the fluidmaster or with the shutoff valve. If the water doesn't run at all after flushing, then instead of cycling the shutoff valve, just loosen the nut where the supply tube attaches to the fluidmaster (under the tank). If the problem is in the fluidmaster, it will start to squirt out at you, otherwise it won't. Then you know what to disassemble and attempt to repair, or replace.
Jan 29, 2010 | Fluidmaster Plumbing
My pegasus won't flush with enough pressure to complete it...
Maybe the shut off valve is not open all the way .....
can you adjust the fill valve so that more water comes into the tank ... more water more flush !
Dec 07, 2009 | Pegasus Technologies Two-Piece Round...
Can't find replacement wter fill valve for Pegasus Cottage toilet
If you replace fill valve with a fluidmaster fill valve that should fix it right up.
Aug 23, 2009 | Home
PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME WE SOMTIME FLUSH 4-5 TIMES
sometimes if you change the flapper and add more water to the tank by adjusting the fill valve they will flush with more power
Aug 08, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Jul 16, 2009 | Home
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
44 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
