Question about Ironman Exercise & Fitness
Belt slipping on ironman inspire
Belt slips while in use
  • 13 Answers
SOURCE: Proform Crosswalk Advanced 525X
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Posted on Dec 01, 2009
  • 18 Answers
SOURCE: belt slipping have tried to tighten, just bought used
When the belt slips, it can be 2 different places. The trick is to look at the front roller when the belt slips. If the front roller stops with the walking belt, then the drive belt (between the motor and front roller) is loose and can't be fixed by tightening the walking belt. If the drive belt is slipping, it needs to be tightened or replaced. I need the brand and model number to help you further.
Posted on Mar 10, 2010
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
bwinton
  • 83 Answers
SOURCE: treadmill belt slipping
bwinton
  • 83 Answers
SOURCE: Belt is slipping and catching
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Removal of back of ironman watch once the screws are removed
Slip something thin (i.e. fine knife blade) under back and pry up. Careful, do not cut the gasket!
Mar 28, 2015 | Timex Ironman 30 Lap 53952 Wrist Watch
Ironman inspire board powers up but the motor will not start when the start button is pushed
see the video and proceed according for fix it. However if after you did LUBE the problem remain. TIME to replace the deck old board completely.see block diagram. God bless you3_26_2013_11_42_43_pm.gif
Mar 26, 2013 | Treadmill Doctor Ironman Inspire Incline...
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
Belt seems to be slipping
As a general rule, the belt should be kept as loose as possible. However, the belt must not slip on the rollers in normal use. Possible overtension can be quickly checked by walking on the belt at a speed of 3 mph The belt must slip on the front roller if you brake the belt with your feet, holding onto the hand rails, while you walk. If the belt does not slip, the tension is too high and the rear roller must be loosened. The belt tension and alignment is done by adjusting the rear roller position with the attachment bolts at the back of the treadmill a 1/4 turn at a time until correct tension attained. T
May 13, 2010 | Tunturi T60 Folding Treadmill
The belt slipped
The belt has probably slipped down below the carrier, it's easier to take the shaft out, install the belt then put the shaft back in. Be sure to turn the shaft top to the front with a 1/4 in. wrench to lock it in place.
DickyO
Apr 14, 2010 | Lexmark Wheelwriter 1500 Typewriter
Belt slipping have tried to tighten, just bought used
Mar 06, 2010 | Exercise & Fitness
My nordic track exp 1000 x slips when the speed is approx. 6. We have tightend the belt and lubricated it. The motor also sounds like it is struggling.
This is usually caused by either a slipping drive belt or a broken front roller/drive pulley. Lower cover must be removed to tighten the drive belt. There are 4 screws located on the bottom of the unit that will release the cover.
Nov 11, 2009 | Ironman Fitness Achiever Elliptical...
Have a nordic track exp 1000x treadmill and the belt is slipping
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Nov 01, 2009 | Ironman Fitness Achiever Elliptical...
Exercise & Fitness Logo
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Tony Crow
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
