Question about Bissell Powergroom Pet Vacuum
Bissell power vacuum canister lid won't close
4 Suggested Answers
SOURCE: Bissell 6595-1 with broken electrical connector
YES! If you haven't contacted Bissell yet (or bought a new vacuum) do so. They sent me a nice refurbished machine for free.
Posted on Mar 25, 2009
  • 17 Answers
SOURCE: bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Posted on Jul 07, 2009
  • 694 Answers
SOURCE: I have a Bissell DigiPro canister vacuum and it
Probably a clog in the hose. Disconnect the hose at both ends. Drop a coin in one end and allow it to fall through and out the other end. If it doesn't, the hose is blocked. Plug the end of the hose into the blower of the vacuum and turn it on. Make sure the other end of the hose is in a plastic bag. This should clear the clog.
Also, check the power nozzle behind the brush. Something may have gotten caught in the elbow near where the wand plugs in.
A full bag will also cause this, or if there's a lot of fine dust in your area, clogged pores in the bag will act the same as a full bag.
Posted on Jan 20, 2011
Bissell little green instruction manual
Hi, it's Jeremy from Crucial Vacuum.
Attached is a copy of the user's manual for your Bissell 1400 Little Green Pro Canister Steam Vacuum:
http://www.bissell.com/assets/0/132/134/228/83bcc4e8-41c1-4b5f-8547-17c9af450a80.pdf
You can purchase direct your Bissell replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 04, 2014 | Bissell 1400 Little Green Pro Canister...
Tip
Bissell Bagless Upright Vacuum not working
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Mar 21, 2010 | Vacuums
Bissell 1631 manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell Power Steamer Deluxe 1631 1 Owner Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 03, 2013 | Bissell 1631 PowerSteamer ProHeat Canister...
Green canister lid wont close
http://smallappliances.electroluxusa.com/en-US/Customer-Support/
download free your instr manual and see your problem lid why not close, go to the section troubleshooting.
God bless you
Sep 27, 2012 | Electrolux Ultrasilencer Green Canister...
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Where can i get a bissell power steamer manual
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
May 30, 2010 | Bissell 1631 PowerSteamer ProHeat Canister...
ON Off Power switch failed Bissell 6900
See this solution:
http://www.fixya.com/support/t371681-bissell_6900_stopped_working_open_thing
Nov 27, 2009 | Bissell 6900 DigiPro Bagged Canister...
Bissell Powergroom Pet Vacuum Logo
43 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
