Question about Bissell Vacuums
Bissell lift off deep cleaner has lost its prime
SOURCE: Pump prime lost
The Bissell 1697 is a temperamental machine. Loosing prime is the biggest problem. I have found that the tanks and top cover are not designed well. The connecting plug on the bottom of the tank does not set deep enough into the female receptacle. When the plastic starts to warp and it will, two things happen. First the push valve on the male side (tank) may not open and secondly, you get air leaks.
The pump wants to pump water with high mass and not air. Once the air purges, it will build pressure. You can watch the lines with the top open and identify where the air is coming from. 90% of the time it is the bottom of the tank fitting.
The fix is to put a spacer under the metal plate holding the male (tank) receptacle in place. A rubber gasket or O-Ring that spaces the plate down about 3/32". The plate must have the holes beveled to recieve flat head screws so they dont stick down and hold the tank off. Use silicon seal. Plate should protrude from the bottom of the tank surface slightly when you are through.
Slipping drive belt to the pump is the second biggest problem. Also if you take the top off, every thing has to go back in place exactly or the top will not fit correctly. Hose routing is critical.
Nozzle's will plug in a heart beat so keep the tank water clean. Make sure you turn the mixture valve to water only and purge the system with water prior to quiting.
One further thing, the vac connections to the tank are crappy. I have to use a foam seal glued to the tank top to mate with the two existing gaskets on the body. Here again the plastic warps and things start not fitting properly.
Most of the problems are related to plastic warping as usual on modern cheap ****.
Bob
Retired Mech Eng.
Posted on Mar 14, 2008
  • 3 Answers
SOURCE: my bissell deep cleaner wont
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Posted on Jul 31, 2008
  • 29 Answers
SOURCE: Bissell ProHeat 2X Select Upright
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Posted on Jun 07, 2009
  • 33 Answers
SOURCE: losing prime on the pump
When the pump loses prime, you just turn of the unit, turn it back on and wait about a minute before pulling the trigger. The pump establishes prime when you first turn it on, but you need to wait long enough to let it get all the air out.
Posted on Jan 24, 2010
My bissel lift off deep clean wont spray water or solution on floor? any tips
the spray nozzles are probably plugged they are like the ones on your car.unscrew the lower part of the head unit should see them there.
Jan 01, 2015 | Bissell Vacuum, Lift Off Deep Cleaner
My Bissel Lift-off Deep Cleaner is not taking up the water from the carpet
I try not to answer questions if I'm not positive of the answer, but I thought I'd give your question an educated guess... With a regular vacuum, if the filter is clogged, the vacuum looses suction. It makes sense, that if your Bissel is otherwise working fine... There's a good chance the filter is the problem. I hope I was of at least some help. Good luck and Merry Christmas, Bill
Dec 19, 2014 | Bissell Lift-Off Pet Deep Cleaner
Bissell Lift off Cleaner - Big tank does not fill with dirty water- Clogged?
Check and clean the filters. Check you User's Guide or call the Consumer Care at 1-800-237-7691
Jul 31, 2014 | Bissell Lift-Off Deep Cleaner 94Y2
NEED A MANUAL
You can find the Online Pdf Manual for the Lift-Off Deep Cleaner (from Bissell's Website) here: http://www.bissell.com/assets/0/132/134/228/c6b03ad1-df14-4284-b6b4-d0de8ada9ffa.pdf
Oct 22, 2012 | Bissell Lift-Off Pet Deep Cleaner
The water is not spraying from my bissell carpet cleaner. What should I try.
check all the o rings attached to each end of all hoses. If dry or crack it will not prime just **** air
Oct 08, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to use the bissell proheat Carpet cleaner 8910
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jan 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Lost instruction book for my bissell pro heat turbo deep clean
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Nov 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Losing prime on the pump
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
xczvc
Dec 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
35 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
