Question about Tag Heuer Formula 1 Alram WAC111A.BA0850 Watch for Men
Wac111a manual Watch has stopped and I need qualified repair
My yves renaud ladies mechanical watch has stopped how do I fix it?
Mechanical clocks (and watches) need periodic service. Your watches probably needs to have it's works cleaned and reoiled. This needs to be done by a qualified watch repairperson, the internals of a watch are very delicate and can be easily damaged. Watch specific oil will also be needed as general lubricants like 3 in 1 and WD-40 can ruin your watch.
I repair clocks and watches daily, I operate a service and repair shop.
Kliks Clocks
Dec 18, 2013 | Watches
Need manual for Tag Heuer CL111A-0
I have the user manual in PDF file. If you still need it so I can email it to you.
Feb 11, 2012 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
Cl111A-0 manual
I have it in PDF file
if you still need it let me know
Oct 08, 2011 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
My watch just stop working,that is the timing just stop working,so what can i do in respect to this and my watch model is( winner rolex ad day tona 1992 24)pls i need an urgent respond.looking forward for...
Unfortunately, for authentic Rolex watches you usually have to get the repairs done by an authorized Rolex dealer. Call your locally-owned high-end jeweler or go online (Google: Rolex Repair) to find an online repair resource. Sorry I couldn't help you!
May 03, 2011 | Rolex Daytona 116520 Wrist Watch
My problem is all of a sudden I have to wind up my watch every morning after it sits on my bedside table over night. It is meant to last over 24 hours without having to wind it up but this all of a sudden...
your watch might have to be serviced. If you are manually winding your watch thats not good at all because it puts unnecessary rapid stress on the sensitive auto reverser wheels possibly damaging the tiny internal clicks. The torque pressure resulting from manual winding of automatic watches is not made for, day-in day-out, manual winding, especially if the watch is not in a pristine new or overhauled condition. It is better to buy a watch winder to keep your watch running.
You should get it looked at by a watch maker who is very qualified or send it to Tag Heuer to get serviced they will give you a quote on how much it will cost before repairing watch so you may decide if you want to go through with it or not.
Sometimes its simple things such as needing lubrication or cleaning. An automatic watch should be serviced every 5 years anyways. So best advice is to get it checked by a well trained professional. My watch guy is great and really cheap . I would ask around make sure you are dealing with a master watch maker though.
Oct 15, 2010 | Tag Heuer Automatic Chronograph Series...
Tag Heuer Kirium Formula CL111C Owners Manual?
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.tagheuer.com/_documents/manuals/EI2245_en.pdf
Oct 12, 2010 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
Is it good to change watch movement to a battery ?Watch was overwound.
There is no such things as over winding a watch. If it is not an automatic watch then the watch will wind until it stops. If the watch does not run then something else is wrong.
If the watch is an automatic then about 30 winds will fully wind the watch. But, you can continue to wind the watch forever. It will never stop winding. Again, if it does not run after being wound there is something else wrong.
To fix your watch you need to have a qualified watchmaker repair it for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 08, 2010 | Kenneth Cole KC1104 Wrist Watch
My swiss army victorinox chrono watch stops about once a week when the date changes, I just tap on it and it starts back up????
It sounds like the watch movement needs to be serviced. A qualified watchmaker can do this for you.
Hope this helps,
Ken
Apr 06, 2010 | Swiss Victorinox Army Classic Chrono...
I have a Breitling Chronomat! I have to adjust the time everyday when I get up in the morning. For some reason it stops working in the middle of the night. I thought that since these watches are automatic,...
They should not stop during the night. You are right.
Several things could be happening with your watch. Either the mainspring is weak, broken or is slipping too much.
This is a repair that will require a qualified watchmaker to perform. Not just any watchmaker can service this watch. they need to have been trained how to service an ETA 7750 movement. Preferably a watchmaker that was trained by ETA.
The movement in your watch (ETA 7750) is a very complicated movement. It has over 450 parts and there are certain parts that require special handling.
Unfortunately the way the movement is made there is no way to repair the mainspring problem without completely disassembling the movement. So this requires a complete service of the movement.
I know this is probably not what you wanted to hear but I hope it helps.
Ken
Yellowstone Watch Inc.
Oct 27, 2009 | Breitling Chronomat Evolution 756...
Tag Heuer WK1110 Date Changing Problem
This could be caused by a couple of things. To fix this would require a qualified watchmaker to repair. The watch will need to be taken apart and the dial and hands will need to be removed to repair this problem.
Normally when we see this problem one of the wheels needs replacing. This can be caused by manually changing the date near midnight.
Let us know if we can help more.
Ken
Oct 05, 2009 | Watches
Tag Heuer Formula 1 Alram WAC111A.BA0850 Watch for Men Logo
35 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
