Question about ASUS P5GC-MX/1333 Motherboard
P5gc-mx/1333 mobo , cpu overvoltage error during starting
P5gc-mx/1333 mobo giving cpu overvoltage error during starting . Error in +5 volt , 12 Volt shown in BIOS . Any solutions ???
SOURCE: realtek high definition audio can not start
download audio driver ASUS P5GC-MX/1333
Posted on Feb 18, 2009
Stakanoff
  • 69 Answers
SOURCE: P5GC-MX/1333 internal audio speaker is not working
Open your case and find a cable that comes from your internal speaker and connect it to pins on motherboard marked pc speaker or int.speaker or speaker
Posted on Mar 21, 2009
SOURCE: what is the solution for P5GC-MX/1333
open link ......
http://support.asus.com/download/download.aspx?SLanguage=en-us
and search for your drivers by putting P5GC in the search box on the left. Select your board and then your OS.
Posted on Oct 06, 2009
jaggujoshi
  • 119 Answers
SOURCE: power supply FOR ASUS P5GC-MX/1333
Dear,
Yes you can use that power supply for both one.
Cheers
Jaggu
Posted on Oct 18, 2009
  • 644 Answers
SOURCE: asus p5gc-mx/1333 cpu fan error
There are usually three wires on a fan to connect to mother board 1 red "+" positive, 1 black "-" negative and 1 yellow which feed the bios with information about the fan, i.e. how many rpms it is running at. To check the fan you will need to open the pc by taking the side panel off, you should do this when the computer is running or you will not be able to check the fan is working or not, but be carefull not to touch anything inside the case. If the is not spinning check the cable is in the socket properly by turning the computer off first, if it is you will need to replace it, other wise the processor will burn out. If the fan is spinning then the bios is not receiving the infornmation from the fan, therefore you need to shut down the pc and unplug from mains and check the cable(give it a littke wiggle) and make sure it is making a good connection, try blowing any dust of the connectors, power the pc again and if the bios is still giving you the same message you will definatly need a new fan, you can by them from any pc store, take the old one with you to ensure you get the correct size fan.
Posted on Jan 25, 2010
I get "cpu over voltage error" during boot up
What is the solution to this problem?
Asus P5GC-MX/1333, CPU = Celeron E1200 1.6Ghz
michel_anhelo3@hotmail.com
Jan 05, 2012 | ASUS P5GC-MX/1333 Motherboard
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
Mobo Compatibility and tech/spec variations
All Asus P5GC-MX/1333 mobos are "X-series" boards.
If you put higher speed ram on that mobo, it will just run the ram at lower speeds.
The board will not take 1333 speed DDR3, because it is only DDR2 compatible.
OVerclocking is complicated and risky, here is neither the place to teach or learn overclocking.
Some newer core 2 chips will automatically overclock, when all but 1 core is in hibernation (which will never happen if you are using vista). Other than that overclocking involves setting the bios to increase the memory buss speed, as well as slightly increasing the cpu and ram voltages as needed for stability. There is a great risk associated with manually overclocking and adjusting voltages, and should not be attempted by beginners on machines they value.
Dec 27, 2009 | ASUS P5GC-MX/1333 Motherboard
Cannot install winxp on asus p5gc-mx/1333
probably ur ram is faulty..replace with a standby n see..
also check for defective capacitors on the main/mother board..
reinstall os..
dis also do happen when ur cd/dvd rom drive is down or the cd frm where u r installing is corrupted..
the above often take place with some error message(s)/blue screen..
but if there's no such displaying, esp if hangs/stops/power off during installation, it may b caused by the main/mother board or even the battery..
..contact ur system admin/vendor....
Oct 29, 2009 | ASUS P5GC-MX/1333 Motherboard
No audio on my mobo
Hey checkout the Asus forum you should find some answer here
http://vip.asus.com/forum/topic.aspx?board_id=1&SLanguage=en-us
checkout these post
http://www.fixya.com/support/t1145581-asus_p5gc_mx_1333_audio_driver
Jul 03, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
I need asus p5gc-mx mother board drivers
I hope you can find there:
http://www.clubic.com/telecharger-pilote-185769-0-asus-p5gc-mx-1333-bios-0410.html
and you can rate the fix.
thanks
Nov 21, 2008 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
Asus pp5gcx motherboard-realtek hd audio driver" failed to install"from cd.
go to the support site for your motherboard, there you will get universal bus architecture device drive. Install this before you install the Audio/Sound driver.
Apr 14, 2008 | ASUS P5P800-MX Motherboard
ASUS P5GC-MX/1333 Motherboard Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
