Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
Bissell quicksteamer there is smoke and a nasty smell coming from my steam cleaner also it doesnt sound right
SOURCE: Bissell steam carpet cleaner
http://www.howtomendit.com/answers.php?id=76173
Posted on Sep 28, 2008
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
Posted on Jan 08, 2009
SOURCE: smoke coming from lower base of vacuum cleaner
Make sure everything is dried off, I encountered the same symptoms once when I had some water remaining in the rotating brush after wiping the machine down.
Posted on May 24, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
  • 20 Answers
SOURCE: My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Posted on Apr 30, 2010
I need to repair my bissell quick steam cleaner
hi , the motors in these units are screwed in the base of the system and have a pulley that spins the roller brush. take the side cap off and check to see if the belt is off the pulley, if so i would make it perform as if something is loose. good luck
May 09, 2015 | Bissell Quicksteamer Powerbrush...
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Bissell quicksteamer 1950 motor
take bottom apart see if belt broke if bad check motor shaft see if it spins
Jul 31, 2017 | Bissell 1960-3 QuickSteamer Plus Upright...
Steam coming out of Miele S7000 upright vacuum cleaner
There is no steam generator on your Miele. It can only be smoke or dust. Are you certain it is steam. If you have sucked up water the motor could be in danger of shorting out.
Aug 12, 2013 | Miele Vacuums
Bissell Steam Cleaner
go to www.bisell.com/how-to-videos/ and use the respectively model and use the common sense for troubleshooting.
God bless you
Sep 06, 2012 | Bissell 1950-3 Quicksteamer Plus Vacuum
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover steam vac smoking
Your problem sounds electrical in nature. I would take it in for evaluation / estimate of service.
Apr 22, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Smoke coming out!
This sounds electrical. If you have had this one year or less then it should be under warranty. find your local Hoover warranty dealer at the Hoover website hoover.com
Apr 20, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
208 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
