Question about Hitachi Heating & Cooling
Unable to set date on rar 2p2 after battery replacement
Remote command date not set
2 Suggested Answers
SOURCE: BROKEN/MISSING HITACHI AIRCONDITIONER REMOTE CONTROL rar-2p2
abhay .hi their is a problem in my remote
Posted on Feb 08, 2010
How to work pave7287 I replaced battery forgot how to setup up time date
Enter the bios and set the time and date there. To enter bios setup pressing the delete key at power up usually works.
Aug 14, 2017 | Time Computers & Internet
My lenovo ideacenter k330b ask me for a command or filename i have block sneen command or filename
If you see "time & date not set", then you need to replace the bios battery on your motherboard.....this is the battery that keeps the time and date settings as well as all the hardware settings for the motherboard. It is a CR2032 button cell battery (see picture below) It sounds to me like the bios battery is dead and the motherboard has lost its config information about your hard drive. Replace the battery (about $5) and check the bios settings to ensure the hard drive is detected. If this doesn't fix it, or if you do not know your way around a bios, then consult a tech-savvy friend, or take it to a qualified technician.
Hope this Helps!!
-Joe
Jan 31, 2013 | Computers & Internet
Libretto istruzioni telecomando hitachi rar 2p2
AVREI BISOGNO ISTRUZIONI HITACHI RAR-2P2 MAIL MARINAADORNA@VIRGILIO.IT
Jul 05, 2011 | Refrigerators
When I press any button on remote it says set 2 and i can't fast forward etc
You could try resetting the remote itself (remove the batteries as if to replace them, press any key on the remote to clear its buffer, then re-insert them or use new batteries) - since your unit is on remote command 2 (or SET 2), try pressing 2 and ENTER/OK on the remote together for 10 seconds, then release. This should now restore your remote to the correct command mode for your player. It may also solve the playback function issue.
The remote for most Panasonic DVD units would need to be reset whenever the batteries are replaced.
I understand the instruction manual does not always help the user.
Apr 08, 2011 | Panasonic DMP-BD30K Blu-Ray Player
Our air conditioner came on by itself this morning. we have been unable to turn it off all day and we are still unable to turn it off. we did however have a wee bit of luck this evening, when we pushed the...
Please check the auto programmed ON/OFF on your remote commander. May be the auto programming is running that run your air conditioner all time without stop. Check also your temperature setting. To hard reset your remote , remove the battery and wait for 1 hour and replace the battery. If your remote has reset button just go has it reset.
Regards, Jay
Dec 25, 2010 | Heating & Cooling
Remote for Sony vcr works intermittently.
Sounds like the connections inside the remote are damaged and might need soldering. Check the connections around where the battery terminals are carefully. Has a battery leaked in the remote?
Jan 28, 2010 | Sony SLV-N500 VHS VCR
Remote will not work. After replacing the batteries I have been unable to get my remote to work. I have updated software/firmware and even deleted all devices and re-entered them. Still no luck. Any...
Point your remote at a digital camera or cell phone camera, and press some buttons. The end of the remote should light up where the IR commands are sent from.
If it does light up, then you may need to learn your commands. If not, then the remote's IR emmiter may be damaged.
Dec 17, 2009 | Logitech Harmony 520 LCD Remote Control
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Date and time etc
The CR2025 Lithium battery, holds the date and time in it's memory and is neccassary for the remote control to work. The CR2025 Type Lithium battery needs replacing. That should sort it. Please rate this solution
Nov 20, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Heating & Cooling Logo
Top Hitachi Heating & Cooling Experts
ka4iup
ka4iup
bobalix
richie46
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
