Question about John Deere Garden
When I start my John Deere Model L118 LIMITED EDITION IT RUNS FOR A FEW SECONDS THEN STOPS. i HAVE CHANGED THE GAS FILTER AND THE FUEL PUMP, BUT PROBLEM STILL EXIST. aNY IDEAS?
nova2nv
  • 197 Answers
SOURCE: John Deere L118 stalls after it runs
2 problems are common with this machine.One is the earlier machines had bad placement of the fuel line at the tank causing it to get pinched off and restrict fuel flow.It may get pinched at the very top of tank where line starts or between very rear of tank and frame.2nd problem is with the decompression setting of the valves causing engine to have too much compression at start up.Set your valves when piston is a 1/4 inch past top-dead-center.Set your intakes at .004.
Posted on Nov 14, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
nova2nv
  • 197 Answers
SOURCE: Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
Posted on May 22, 2010
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
I have a John Deere L118 limited edition the PTO to engage mower will not work
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
May 10, 2017 | John Deere Garden
My John Deere 145 won't crank. it acts as if it is not getting gas to the carburetor. we have changed the modulator, checked the fuel lines and fuel filter. the gas is clean. can you help?
put a little gas in the carb and try it. if it starts for a few seconds and dies it is starving for fuel. be sure fuel is going through the fuel lines to the carb. if so the carb itself may just need cleaned.
Apr 15, 2017 | John Deere Garden
John deere L118 engine just stopped while mowing like it ran out of gas or electrical shutoff, started back once and ran for a few seconds and died again. it just had a tuneup last month, I also put o
WATER IN GAS CLOGGED CARB REBUILD IT IF WATER IN GAS DRAIN IT OUT DRIAN CARB BOWL MAKE SURE NO WATER IN IT TRY TO START IT IF DOES SAME CHECK COIL SEE IF IT IS SPARKING WHEN IT SHUTS DOWN IF NOT REPLACE COIL 60.00 THEN CHECK FUEL PUMP GOOD PRESSURE 3TO 5 LBS CHECK ALL THIS AND LET ME NO WHAT HAPPEN WILL GO FROM THERE TO CHECK MORE THE REDNECK
Sep 01, 2014 | Garden
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
I have a John Deere L118 Limited Edition (w/ 20 HP B&S engine), which I purchased about 8 years ago. It ran well with few problems up to late this summer. I believe the problem started when I...
The gas cap has a small hole in the middle that needs to be unplugged every year! Just take a paper clip and stick it in and move ot around. It allows the tank to breath. Let me know if this works at mmacis@msn.com.
Nov 21, 2010 | John Deere Garden
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
Garden Logo
27 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
