Question about Ovens
Proline oven EF 6400SS - Ovens
Can you use oven pride on the proline FE 500w cooker
No this is NOT advisable... just use elbow grease and caustic.... or a spray on cold cleaner.
May 12, 2011 | Ovens
Need a manual for stoves 720 ef double oven
Supply an email address and I will register you on my BT Digital Vault where you can access and take a copy of the entire handbook
Dec 31, 2009 | Stoves 720EF Electric Double Oven
I am trying to get instructions for stoves oven 720 EF
I have a copy of the Handbook on my BT digital Vault. You can have a copy if you supply an email address to validate access.
Nov 03, 2009 | Stoves 720EF Electric Double Oven
720 EF Fan oven fan making a scrreching noise now
It could be that cooking residue has run down the inside of the fan cover and it is restricting the fan movement. The fan cover is held on by four self tapping screws, one on each corner. Remove the cover and have a look to see if there are any rub marks on the inside. You should be able to remove some of the gunge by soaking the the whole cover in hot soapy water. If that doesn't work, buy the Lakeland brush on oven cleaner - that definitely works - you can use it on all of the inside of the oven. Whilst the cover is off, briefly turn the oven on to see if the fan still makes the same noise. If it does, it looks like the fan bearings are suspect and a new fan may be required. If not you have found the problem with the cover. Page 37 of the Handbook tells you how to replace the circulating fan.
Sep 23, 2009 | Stoves 720EF Electric Double Oven
My proline electric single oven is not heating up
most likely the heating element needs replacing, about 25 $ part.
Aug 31, 2009 | Ovens
I need an instruction manual for a stoves heritage 720EF oven
I have just uploaded a scanned copy of the stoves 720- EF manual to the link below.
Requires the free Adobe Acrobat Reader or similar software to view the manual which most computers already have. The stoves ef720 manual file below is full and free of charge
http://wl.filegenie.com/~simun/Stoves720EF.pdf
Jun 02, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
