SOURCE: Chain saw will not start
BEFORE YOU DO ANYTHING, CHECK THE
CARBURETOR AND FUEL LINE FOR GUMMY
DEPOSITS. TODAY'S GASOLINES DEGENERATE AFTER STANDING FOR LONG
PERIODS. IN THE FUTURE, WHEN YOU ARE
DONE WITH THE CHAIN SAW, EMPTY THE GAS OUT AND RUN THE SAW TIL THE CARB IS FREE OF RESIDUAL GAS.
SOURCE: not getting oil to the
Not all machines have an adjustable oil pump, if this is a Husqvarna, let me know the model, and i will tell you if and how to adjust it.
try this click here .. been awhile since i worked on one. it is nice to have lots of oil, but should be same as a tank of gas .. jay the pool pump repair guy florida
SOURCE: not getting oil to blade tried the screw to adjust but still no oil getting throu !!
Your worm gear assembly is probably frozen in with sawdust and dirt. Take off the oil gear assembly. You will need to take off the clutch and the sprocket, the worm gear is directly underneath. Sometimes they are made out of plastic, sometimes of bronze. They use plastic for newer saws. If the gears do not turn easily, when you use your finger to turn them when they are off. then it is probably a good idea to buy a worm gear and then totally clean the assembly. Put in the new gear and it should work. Also check your chain bar check that the hole is clean. They also have a seal around the worm gear under the clutch assembly. It is good that you replace that too.
