Question about Camping, Backpacking & Hiking
Need AC wall charger for SBS2000H3
Lost my AC charging adaptor for my high output spotlight producr is SBS2000H3 distributed by Ultimate illumination laboratories
  • 973 Answers
SOURCE: replacement 6v charger for Garrity spotlight
Contact Garrity at http://www.garritylites.com/contactus.html
Posted on May 25, 2010
  • 973 Answers
SOURCE: I have a 139c spotlight and i lost my charger
You can purchase one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
CarlGlas
  • 283 Answers
SOURCE: Recharging - indicator lights when complete
When the green light stays on that means the battery is fully charged. The correct charger for that light is a Class 2 Transformer
Model: KA12D120030042U It has a output of 12VDC at 300 mA
Posted on Jul 07, 2010
  • 14 Answers
SOURCE: need ac charger for vec
Radio Shack sells AC/DC replacement power adapters that will work. Also RV places such as Boat and RV found local or online. Google Boat and RV and they have chargers there for about 12.00 - 20.00. Hope this helps! Matthew
Posted on Jan 22, 2011
  • 43059 Answers
SOURCE: I need a 15v wall charger for an Ultimate Illumination Laboratories spotlight model SBS2000H3. Where can I get one?
Perhaps the manufacturer's website .
Posted on Nov 22, 2015
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Looking for a 120V to 12V charger for a Professional"s Favorite 17.5 million cp spotlight.
You should be able to use any AC adaptor that puts out a 12 volt DC current and has correct polarity. Based on the estimated size of the battery powering your spotlight, you probably will want a charger that provides at least 1000 mA of power--the charger that came with my ThorX 10 million cp spotlight puts out 1500 mA to charge the two batteries in that light. A lower amperage rating will increase the amount of time it takes to charge your light, but it should still work.
You can find a replacement charger at Radio Shack, which sells chargers that can be fitted with a variety of different tips. However, you might be able to find a cheaper universal charger with a tip that works at a discount store like a Walmart, or you might get lucky at a thrift shop or second-hand store and find a 12v charger that will work with your light. 12 volts is a common output for a lot of different devices, so it shouldn't be hard to track a replacement down. Just make sure you have the adaptor tip polarity correct, or else you could make your battery explode if you try to charge it with reversed poles.
May 25, 2011 | Camping, Backpacking & Hiking
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
May 29, 2010 | Vector 2M Pwr Rch Spotlight
Xantrex Inverter/Charger has no AC output
HI
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
May 21, 2010 | Kitchen Ranges
Hello all you electronic nerds. I have a simple question so please do not try to give me a college education in your answer. I have an 16.8 drill battery without a charger. i need to find out if it will...
No. Not unless you also use the right size diode to make the AC go in one direction only.
AND---- Don't try anything like this with a Lithium battery! We're talking NiCad, right?
May 06, 2010 | Ryobi Multi-Volt Battery Charger
Lost Power to camera
well you should lurn from this,,only use the charger that comes with the unit,,,im sorry to tell you this but you more that likley have done your camera in was the charger you pluged into your camera the same voltage and polarity as the cameras normal charger?
if it was in revers you would have cooked the camera
Nov 05, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
382 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
