Question about Kitchen Appliances - Others
Weather station, Model WHO100
I would like to have a manual for setting up my weather station, Model WHO100
SOURCE: Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Posted on Apr 16, 2008
  • 11800 Answers
SOURCE: my midalnd weather radio WR-100
The high pitch sound is a sign of the autooscillation of the intermediate frequency amplifier from the tuner in your radio - hardware defect. The only way to fix that is to replace the tuner and realign it. This would cost you about $100 for the part and labor.
Since you can buy a brand new unit for less than $40 it's clear what you should do.
Posted on Jun 13, 2011
  • 5159 Answers
SOURCE: Need set up manual for The Weather Channel indoor
The manual for the thermometer is available on the LaCrosse site: http://www.lacrossetechnology.com/7034twcit/index.php . The direct link is http://www.lacrossetechnology.com/7034twcit/manual.pdf .
Put the batteries in the remote(s) first. (If you need to reset the units, pull the batteries from the indoor temperature sensor and the remotes for 10 minutes before restarting.) With the remotes and indoor sensor 3 to 5 feet apart, put the batteries in the indoor temperature sensor. Then wait 10 minutes before pressing any buttons. Once you have confirmed communication between the units, then move the remotes to their final location (not more than 330 feet away minus 30 feet for external walls or windows and 20 feet for each internal wall between the units.)
I hope this helps.
Posted on Jul 08, 2011
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Posted on Nov 06, 2011
SOURCE: auriol radio controlled weather station instruction manual Z29962E-RX
if the indtruction manual is not english then google the brand name and email your information model number etc.. ask them to email you a copy in english
Posted on Dec 26, 2011
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
1690-34bk manual
Lost my manual on how set this weather station.....please point my into the right direction
Jan 09, 2013 | Leeds 169034BK Affiliate 15 Inch Weather...
Need instructions for model #2316 La Cross technology weather station. How do I set the date and time?
per the manual at http://www.lacrossetechnology.com/2316/manual.pdf on page 2 section 5 the unit sets its self to the world time radio signal from boulder colorodo on its own after it get the security code from the sensor pack.
Nov 17, 2010 | La Crosse Technology Technology Weather...
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Kitchen Appliances - Others Logo
66 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
