Question about Precor 9.21 Treadmill
Error code PW? on precor 9.31 treadmill - Precor 9.21 Treadmill
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Posted on Feb 12, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Precor C956 treadmill reads erroe code 45. what
Error 45, Lift Moving in Wrong Direction It maybe the lift motor itself the potentiometer maybe defective, the ribbon between upper and lower boards
Posted on Mar 01, 2010
SOURCE: We are getting an error
we have erorr 22,42,26
Posted on May 02, 2011
ercupa190
  • 12223 Answers
SOURCE: 9.1.0 TREADMILL PRECOR PACE ERROR
Dear Sir:
Hello I hope everything is fine.
I will give some Tips:
Description Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed. Possible Causes 1. These errors messages almost always indicate an upper PCA problem when they are consistently displayed. Failures causing these error messages to be displayed are rare. Possible Remedies 1. If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see one of these messages displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in one of these messages being displayed. Treadmills operating on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
Thank you in advance , sincerely. Blessing. If you need additional Help, please do not hesitate to contact me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Posted on Sep 27, 2011
Error code AC-6
ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
Jan 19, 2016 | Exercise & Fitness
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Treadmill error code 16
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Mar 28, 2014 | Precor Exercise & Fitness
Error codes for 9.17
This link will take you to some common error codes found on most Precor exercise machines:
Dec 12, 2013 | Precor Exercise & Fitness
Precor treadmill code e3 is on
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Precor error 15 input voltage
Precor Error 15, AC Input Voltage Too High Probable Cause 1. AC input voltage is incorrect.
2. AC input voltage transients. Transients can be caused by lightning strikes or by other pieces of equipment sharing the unit's AC power.
Corrective Action
  2. Ensure the AC grounding for the unit's outlet is good and verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error Code 15
May 18, 2013 | Precor C966i Treadmill C 966i
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Precor Treadmill 9.21si Error Code 26, what does it mean
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Precor 9.21 Treadmill Logo
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
