Question about Precor 9.21 Treadmill
What does PW? stand for on display panel for precor treadmills
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
Posted on Mar 06, 2011
ercupa190
  • 12223 Answers
SOURCE: My Precor 9.31 does not respond to the down arrow on the left hand side of the panel. The PW? requires the left down arrow, and the right two arrows to be pressed consecutively. Unfortunately, the l
1) Clean the contacts, with contact cleaner spray( radio schack or computer store) if you remove the cover will be better for to do it. With carefully and disconnect the power cord for to avoid danger to you and the equipment.
2) If you can adjuts after that sensor reed switch to 1/8" see the diagram attached, will be good, and will be
good idea if you replace the sensor reed switch or optical disk.
3) After that you can conclude if the problem persist after adjustment or replace the sensor the trouble will be the display console faulty, Do not conect anything after you are right with your problem..11_18_2011_4_58_22_pm.gif
Posted on Nov 18, 2011
  • 95 Answers
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Posted on Jan 13, 2012
ercupa190
  • 12223 Answers
SOURCE: Parts for a PreCor 9.1 treadmill
go www. precor.com or www. fitnessrepairparts.com or www. treadmillspartszone.com
God bless your
Posted on Jul 07, 2012
Precor EFX 546i display is not working
Troubleshooting Treadmill Control Panel Issues Green Fitness Company
However test the voltage supply from Control Board Motor to the PCB console, by 8-12Vdc, if does NOT appear replace the Control board motor.
If there are Replace the Console Board Display.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Dec 11, 2017 | Precor Exercise & Fitness
My PRECOR TRM 800 wiht the P80 console will not work with Quick Start.
If rebooting the treadmill does not fix that, it may have a problem with the Autostop feature. The MCB may need to be replaced to fix that problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
May 27, 2014 | Precor C956i Treadmills with HR /...
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
Precor error 3
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
Precor treadmill code e3 is on
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Precor 9.35 Error 5
please see the details and proceed according. God bless you
Dec 12, 2012 | Precor 9.35 Premium Series Treadmill
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
My Precor 9.31 does not respond to the down arrow on the left hand side of the panel. The PW? requires the left down arrow, and the right two arrows to be pressed consecutively. Unfortunately, the left...
Nov 18, 2011 | Precor 9.31 Treadmill
Precor 9.21 Treadmill Logo
44 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
