Question about Toshiba 27AF45 27" TV
I have a D770 Universal remote to control my Toshiba 27AF45 TV How do I switch to the video so that I can watch a dvd?
I can control the channels and the volume and on/off but can't switch to watch dvd or video games
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
  • 15 Answers
SOURCE: How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Posted on Jan 12, 2009
a1electronic
  • 30 Answers
SOURCE: Toshiba 27a45
yes a universal remote will work but you may need to try several to find one that will, not all work to select your inputs. first try changeing the channel below channel 2, thats were most tv inputs are located (accessed)..
Posted on Jul 20, 2009
bbl242003
  • 1637 Answers
SOURCE: After 5 yrs.of excellent performance, my Toshiba
CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s
Solution 1
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution.
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 25, 2011
gopakumarg43
  • 74251 Answers
SOURCE: toshiba 27AF45 turns off. Have noticed it is
Hello
The video IF section of your TV should be troubleshooted. It is a really vey skilled work, needs through knowledge in electronics, and seperience to follow the schematic diagram of the main circuit board. Even an expereienced service technician may also take some time to detect the actual fault point.
This is the picture of the main board to your TV. If you can get it new, it will be best to replace it as card basis. OK.
Posted on Jan 05, 2012
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
Hello
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
I have a Toshiba 27AF45 and a RC64 remote control which is not what comes with the TV. It works ok but I cannot figure out how to turn on the closed captioning feature. When I enable the menu I do not see...
Unfortunately, TVs don't always work with universal remotes. The original remote probably had a button to control the captions, and there may not be any other way to access those settings. If you can't find caption control settings using the on-screen menu, you are out of luck. The only options then are to try another brand or model of universal remote that may have a button which will work, or to locate a replacement original remote control.
Jun 21, 2011 | Toshiba 27AF45 27" TV
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
Hi, looking for the code on a Toshiba TV 27AF45 and also for a Panasonic DVD player # SAHT730
Hello
For what code you are asking about? Is it universal remote control setup code?
Feb 13, 2011 | Toshiba 27AF45 27" TV
Hi i have a universal remote px-rc1 and i dont know what is the code for toshiba tv 27AF45 model and how to set it so that i can switch between tv and video(AV) modes. please help me with this
Hello
Three digit universal remote codes for Toshiba TV are:
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit codes are:
0240 0261 0260 0287 0290 0358 0369
0924 0398 0274 0341
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jan 25, 2011 | Toshiba 27AF45 27" TV
27'' symphonic TV. Sony remote wont work since switched 2 digital
Use the channel buttons on the unit to go down past channel 2, usually you can get to the inputs this way.
Aug 09, 2009 | Sony Televison & Video
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Input
If you can use the universal remote to turn the set on and off then your TV is fine. Universal remotes won't control all aspects of the TV.
Mar 24, 2007 | Toshiba 27AF45 27" TV
Toshiba 27AF45 27" TV Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
