Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Same tv but smaller
I have a pt47w49 and i did the unthinkable. i went in to the service menu to try and fix a slight convergence problem, and now my picture is all screwed up! is there a reset or a way to recall defaults?
  • Panasonic Master
  • 5,138 Answers
Sorry there is no reset for this alinement,you probly need your ics replace and complete convergence alinement ICs are STK-392-110s or 150s , I myself replace them with 180s.
Posted on Dec 21, 2007
I own a RCA d52w20 and the convergence is terribly bad. I set it up, used auto convergence and even went to the service menu for the 25 point setup. But my screen is still terribly bowed and i cannot find...
Try this with TV off Press and Hold CH- VOL- at same Time Hold untill TV comes on.
Then you should be in Factory setting menu, it will either corect the Problem its self or go straight to Service Menu for Techicians.
Feb 24, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
By admpeek on Jun 25, 2008 When I turn it on the picture is concaved, the color is shifted slightly to one side, and there are 3 skinny lines across the top. I went to convergence menu and clicked it...
You have a blown fuse on the Deflection board FL231 it will be on the righthand side of the flyback Transfomer there are 3 of them in a row they will look like small brown retrangler caps, it will be the one in the middle. I had this problem myself just several months ago, replacing this fuse fixed the problem. That fuse controls the convergance of the 3 CRT's, without it the tv can't converge so you don't get the option in the menu.
Sep 17, 2010 | RCA HD52W66 Projection Television
My tv went multi colored take it as it looks like a 3d television
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
You can see some more examples and find a fix using this link on Fixya
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
Convergence problem ,Help Please
Something is not right here. Is there any possibility that you can get the circuit designation (Rxxx) of the resistors that were "incorrect"? I am not aware of anything like this that can cause the "memory to be erased". The only memory in that area would be the factory convergence settings which can be modified from the service menu. Please try to supply the resistor IDs and I'll check on this.
Feb 13, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My HD52W67 has concaved picture
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Jun 25, 2008 | RCA HD52W66 Projection Television
Could you tell me how to get into the service menu of my toshiba rear projection tv?
Most TV repair shops have a warranty 30, 60, or 90 days. Call him back. You probably have a convergence IC failing or a resistor changing value in the green convergence output circuit.
Jun 04, 2008 | Toshiba 57H81 57" Rear Projection...
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Blue convergence
if the problem as atated only needs rotation, then your need to turn the yolk on the blue tube. you will have to slightly loosen the screw that hold the yolk. rutate it the proper way to get it aligned with the other colors. retighten the screw, but do not over tighten, you do not want to break the tube. ALSO make sure that you do not move the yolk UP or DOWN. if so the blue picture will be resized. down the picture goes smaller, up the picture gets bigger. good luck.
Dec 24, 2006 | Hitachi 60EX01B 60" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
