Question about Philips HD2548 4-Slice Toaster
Replacement parts Will not hold to toast bread?
Why does my toaster ony toast one side of the bread
Because the nichrome wire on one side of the toast has broken.
Its time to get a new toaster.
Mar 17, 2015 | Baking
The bread only toasts on one side (each piece)
I take it it that the outside is being toasted and not the part between the slices? That would mean that the element that is shared by the two slices has burnt out. Check with a dealer for a replacement.
Jan 20, 2011 | Hamilton Beach Eclectrics 22111 / 22112 /...
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
Replacement part for a toastmaster bread box
This site may help you:
http://www.vendio.com/stores/breadmakerguru/item/toastmaster-parts/toastmaster-breadmaker-kneadin/lid=2740562
It is for Toast master bread machine parts....just scroll down their list until you find your model # and click it
Please give me a ranking/rating/vote so I can help otherw with their bread machines too...Thanks!
Oct 18, 2010 | Toastmaster Kitchen Appliances - Others
My toaster only toasts on one side of the bread...can I replace the toasting elements? It's a Kitchen Aid brand.
The kitchen aid brand is usually a good one,
i prefer you too replace the toasting elements because in my brand i faced the same problem and i replaced the toasting element . it worked wonders for me
Dec 29, 2009 | Kitchen Appliances - Others
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Philips HD2548 4-Slice Toaster Logo
Top Philips Kitchen Appliances - Others Experts
Dennis Maeder
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
