Question about Amana ACF3355AS Gas Kitchen Range
GE Double Oven won't heat up past 100 degrees. Turns off after a minute or so. Upper oven only. (electronically controlled)
Starts to heat up but then cuts out after 1 minute or so
catriver
  • 878 Answers
SOURCE: My oven will not heat...
Dean, sounds like your ignitor failed. This is a pretty easy job that you can do by yourself. Usually there is 2 screws in the oven bottom in back that come out. From there you lift the bottom panel out exposing the flame spreader. Remove the flame spreader and the ignitor is sitting right there. This is usually held in with a couple 1/4 in hex screws. The new ignitor will either come with a harness or just wires. You can splice the new one in with ceramic wire nuts or if it has a harness, follow the wiring to where it connects. I find just splicing the new one in is easier. I have 2 part numbers depending on your P-number..0316223 and 3194001. Look them up on the net and see which one matches your ignitor. Catriver...post back.
Posted on Dec 09, 2006
SOURCE: incorrect temperature in oven
refer to the manual about setting the temperature. When the unit ships from teh factory they set the temp. you may need to recalibrate it.
Posted on Sep 03, 2008
SOURCE: Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
Posted on Dec 01, 2008
crayzeetrayn
  • 837 Answers
SOURCE: temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Posted on Feb 08, 2009
SOURCE: amana ACS3350AS stove temp in oven stays at 100
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Posted on Mar 24, 2009
JTP86-30 Oven is not heating. Neither element in the oven heats. I can hear the 'click' I'd expect when it starts to heat. The fan starts up and the readout shows 100 degrees. It never changes and the...
Many GE oven control boards have a relay for the common of the broil and bake elements. This relay is notorious for being the culprit. the electronic control board will need to be replaced. You could check with corecentricsolutions.com to see if the control can be rebuilt. It is much cheaper but you will have to send the board to them for repair.
Mar 28, 2014 | GE Wall Oven Plus Microwave - Model...
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
Oven won't heat up past 200 degrees
The temperature sensor needs to be checked.It must not working properly. thanks.
Oct 11, 2011 | GE JTP45 Electric Double Oven
I have a GE JTP27 double oven, now 12+ years old. For last 2-3years, having consistent problem with upper oven where, after oven heats up and/or starts baking, we suddenly get a beeping sound and an error...
Greetings,
its possible to be the oven sensor or something in the lock circuit...if all else fails then in the electronic oven control which costs 125.00 or there about...might find cheaper price on ebay or internet search The sensor about 40-60 dollars, but without a complete number its hard to be exact with a price or part list...if this is helpful ..please let us know or if I can be of more assistence. let me know...Bruce Denton
Dec 28, 2010 | GE JTP27 Electric Double Oven
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
It turns on but won't heat past 100 degrees.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 26, 2010 | GE Profile JS968 Electric Kitchen Range
Oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Amana ACF3355AS Gas Kitchen Range Logo
16 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
