Question about Marantz Audio Players & Recorders
My marantz cd 7300 reads no disc probably needs a new laser, where do i get one, thoes sold on ebay look different, many thanks, Peter.
This sounds crazy but it works for some reasons. Marantz CDR500 would not read and initialise some blank discs but no problem with reading finalised ones and erratic would and would-not work. Tried cleaning lens and even blowing ar through it. Before I wasted money in air I thought why not try hairdryer into open tray and lens area and just for measure across blank CD. I know this sounds weird but it worked every time and machine will read any make of disc like this. I do not have any scientific explanation only the fact that it works!!!
Posted on Jun 03, 2017
shanth
  • 108 Answers
SOURCE: Technics Cd player doesn't read disc. Says no disc.
You cannot replace the new lens your self. coz there are some process to replace a new lens. withour much knowledge of servicing you might damage the new lens too.
try to find some substitute for your technics lens
Posted on Dec 22, 2007
welcomejee
  • 10594 Answers
SOURCE: Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Posted on Jan 15, 2009
satavlad
  • 405 Answers
SOURCE: My Marantz CD63SE SPECIAL EDITION CD PLAYER won't read discs
Most likely, new optical (lazer) pick up required to solve this issue.
Posted on Dec 01, 2009
  • 99 Answers
SOURCE: Laser is malfunctioning on my Marantz CD Recordable DR6000
the laser in your DR-6000 is exactly the same as what's in the philips cdr-775 and cd-r-770.
a brand new laser for these are very hard to get hold of and are very expensive. personally i would look out for the above philips models on ebay for less money then take the whole mechanism out and unscrew the servo board and then fit the marantz servo board in place of it and fit it back into your recorder.
i have done this on numerous occasions with no problems.
hope this helps.
Posted on Sep 12, 2010
  • 99 Answers
SOURCE: Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Posted on Sep 01, 2012
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
Marantz cd5001 stopped playing in mid-stream. Now inserting disc makes no laser clicking/noises, not reading. I have part with laser out, it's a sony laser attached to a metal plate SM213CCM then below...
Hi Robert,
Before you replace the optical lens try this first.
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty, click this for the replacement
http://shop.ebay.com/i.html?_nkw=Marantz+cd5001&_sacat=0&_odkw=WS-65809&_osacat=0&_trksid=p3286.c0.m270.l1313.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 02, 2011 | Marantz Audio Players & Recorders
Hi.I have CD Recorder Marantz DR6000.After reading and initalizing blank CD-R Audio next on display show OPC ERROR.It,s reading all audio CD,s,oryginal,and CD-R.When I wanna finalized old CD-R,recorded by...
DR-6000 only accepts CD-R audio or CD-R music discs, not the standard CD-R discs. the difference is that the audio and music discs have the OPC formatted differently and they cost a bit more because they include the royalties fee. Standard CD-R discs won't work in this recorder. The correct discs have compact disc "digital audio" logo on them.
Oct 01, 2010 | Marantz DR-6000 CD Player
Nov 30, 2009 | Marantz Audio Players & Recorders
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
hope this helps.
Feb 26, 2009 | Marantz DR-6000 CD Player
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
CD door not opening.
Usually failure to open means a faulty motor - when you press eject ca you hear the motor spinning or is it quiet? If in the UK contact me via ebay - fluffcat1 - and I can help further.
Jan 20, 2008 | Marantz DR-4050 2-Disc CD Recorder
139 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
