Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My scandisk cruzer broke and i need the info from it
I accidentally bumbed into the cruzer and it bent. It will light up if i hold it into the usb drive,,however it still does not connect to any computer. Is there any way to retrieve the data that has been saved onto my scandisk??? PLEASE LET ME KNOW ASAP. School is depending on it!! Thank you so much!!
  • TJNani Mar 08, 2008
    My SanDisk cruzer micro 4gb no longer lights up and is not showing the data. The computer does not recognize it when it's in the usb port. Is there a way to retreive the data on it??
  • kendra_06 Apr 06, 2008
    i have a scandisk cruzer micro 2gb. my friend downloaded songs for my ipod onto it and now i cant retrieve the songs.somebody help me please.
Just burn it and get rid of it !!
Posted on Oct 10, 2007
SOURCE:
Instructions how to transfer my photos from picasa to scandisk cruzer 4GB
click start all programs accessories open windows explorer navigate to your photos the files right
click on the photos right click copy navigate back to the destination drive right click select paste or hold the mouse cursor the photos drag them to destination folder then drop them in
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device floppy or a usb device
if you need more help with this post a reply
hope this helps
Jul 28, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My ScanDisk cruzer micro 2.0 stop working. The orange light won't turn on and no respond. I don't need to get another ScanDisk. I just want to have all my documentations. Is this situation fi
I would try several different USB slots if you haven't already. Unfortunately, if it doesn't light up, there's not much you can do, other than take it to a specialist. Sorry.
May 02, 2012 | Computers & Internet
My SanDisk Cruzer was in the usb port when my husband accidentally turned the tower face down. Today I noticed the disk will not light up. It is bent slightly. Can you help? all my imortant files are on...
If it will not work when you put it in the computer, then the flash drive is probably just broken. You could always try to bend it back, but that may only make the problem worse. Sorry. Best Wishes!
Mar 28, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 2gb cruzer micro usb broke
if the usb connector broke off of the board inside the plastic casing, no, you wont be able to retrieve the data.
May 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
MY CUPTER WILL NOT RECONIZE MY CANDISK
Your Scandisk may need formating to get it working again.
For my instructions and info on this procedure please click in this link :-
http://www.fixya.com/support/r3598107-faulty_usb_flash_drives
Dec 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Scandisk micro syncs all 'My documents' with comp plugged into
open scandisk settings and disable that feature.
or else you can simply delete scandisk software and use your pen drive.
Sep 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My scandisk cruzer micro 2GB
It sounds like your Cruzer is bad and needs to be replaced.
You could try to replace it where you bought it. (This would be the easiest way)
Or you can send it to SanDisk
Here is a link to their warraty proceedure.
http://www.sandisk.com/Assets/File/Downloads/Warranties/SMLW_ENG.pdf
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
Apr 27, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Can't detect my scandisk cruzer micro
hi mate, what os are you using on your notebook
it it in't xp its a driver problem, not your sandisk 2gb card
here are the specs for it,
  • Retractable USB connector
  • Brilliant amber LED
  • U3 smart enabled
  • Loaded with the following U3 programs
    - CruzerSync synchronization software
    - SignupShield password manager
    - SKYPE "Make video calls from PC to PC"
    - AVAST antivirus software
  • Hi-Speed USB 2.0 certified (backwards compatible with all USB 1.1 ports)
  • Compatible with Windows 2000, SP4 and XP*
  • Certified Windows 2000 and XP*
  • upgrade your notebook to xp
    Nov 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Cruzer Scandisk 2.0 titanium
    Hi, Not unless you are using Windows98, your PC should automatically recognize the SanDisk Cruzer Titanium as a "Removable Storage/Device". Driver is not required for Windows ME, W2k or XP. If for some reason the SanDisk Cruzer Titanium (non-U3 devices) is not recognizable, then perhaps it is not a problem with the PC but with the SanDisk. Pls try all other USB ports of your PC (front and back). The SanDisk website provides utilities/software for this kind of eventuality. They are Sansa Firmware Updater and Sansa Connect Recovery Tool. Both are available at http://www.sandisk.com/Retail/DriverDownloads.aspx. Pls be forwarned that some utilities can and will reset your SanDisk to default and any or all data can and may be deleted. Hope this be of some help/idea. Pls post back how things are or should you need additional information. Good luck and kind regards.
    Sep 30, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
    SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
    206 people viewed this question
    Top SanDisk Computers & Internet Experts
    Ekse
    Alun Cox
    k24674
    Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
