Question about Winchester Safes Combination Lock. Deputy 14 Gun Combination Lock UL
WINCHESTER GUN SAFE TS-9,ACCIDENTLY TURN LOCK AND LOCK DOOR HOW I CAN UNLOCK,LOCK DOES NOT GOES ON NOON POSITION
How do I change the battery on a winchester gun safe door?
Winchester uses several different brands of locks. You need to be more specific as to the lock that is on your safe. However, most batteries are contained in a housing on the under side of the code entry pad.
S&G batteries are usually removed by simply pulling slightly forward on the tab on the housing on the base of the lock. The housing will then drop down and you can change the battery.
Some locks will actually have the battery contained inside the code entry pad housing which can be removed by grasping the entire key pad housing and rotating the housing a few degrees counter clockwise, and then pulling the unit straight toward you.
Some locks may require you to remove a screw, but most do not.
A more specific description of which lock is installed in your safe will allow for a more specific answer. A picture also helps.
Mar 01, 2015 | Optics
How do i program a keyless remote for a chevy 2002 S10?
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
Mar 05, 2010 | 2002 Chevrolet S-10
Winchester Safes Combination Lock. Deputy 14 Gun Combination Lock UL Logo
497 people viewed this question
Top Winchester Safes Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Winchester Safes Lock and Locksmithing Expert? Answer questions, earn points and help others
