Question about GE ZDW24A Wine Cooler
I have a 11 year old GE Monogram Wine Chiller (ZDW24A) that stops working every few days until I turn the thermostat a few degrees in either direction.
No ice build up. Chiller stops working every few days until I turn the thermostat a few degrees in either direction.
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: I have a GE Monogram Wine cooler model ZDB24AABB cooling fan
No switch. Fan motor going bad and must be replaced.
Posted on Feb 21, 2009
  • 358 Answers
SOURCE: Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Posted on Nov 04, 2009
197jacobs
  • 226 Answers
SOURCE: Have a GE Monogram Wine
it needs freon a certified sevice
Posted on Oct 15, 2010
I have a GE Monogram Wine Chiller ZDW24A RBB. Everything works fine, but today the light stopped turning off when I shut the door. I checked the sensor on the bottom and it seemed to be in order. H
On the right of the thermostat on the grill below the door is a rocker switch, turn it off as this is a light switch not a power to unit. Its just the switch was turned on during your cleaning process. Good Luck
Oct 14, 2014 | Furniture
My GE Profile Wine Center stopped cooling
Switch off, leave 5 mins then switch on again. Check display again.
Apr 22, 2012 | GE Profile FreeStanding Deluxe 29 Bottle...
Nov 04, 2009 | GE ZDW24A Wine Cooler
The compressor and the fan don't run.
its your contactor or the wire feeding it
Aug 16, 2009 | GE ZDW24A Wine Cooler
Thermosthat doesn't work
Hi , yes it sounds like the thermostat is stuffed.  To replace it is relatively simple but always keep in mind , switch off and un-plug it before working on it for safety ,  to replace it you will need a phillips head screw driver , a flat screw driver and a note pad,  where the dial is , that is the thermostat , the surrounding screws are what hold it in position so removal is only a matter of having a real good look inside . Thermostats for this purpose are about $15 to $35 dollars depending on your country . replacement time is about a hour depending on how much trouble to have getting the old one out. remember that this device has a small alloy tube which is the sensing part of the thermostat , be careful not to damage this because it carries a small refrigerant charge which is the primary temperature sensor so please be very careful and above all take your time .
I hope this helps you ,
Thank you and have a nice day:)
May 12, 2009 | GE ZDW24A Wine Cooler
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
GE ZDW24A Wine Cooler Logo
Top GE Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a GE Furniture Expert? Answer questions, earn points and help others
