Question about Technics SCEH790 CD Shelf System
Fisher DCS-S450 CD Audio Shelf System - Technics SCEH790 CD Shelf System
What is the code for a universal remote for the Fisher slim 1500
If you have a universal remote, try its code search function to find a suitable code. If you search through all codes stored in the remote without success, you may have to try another universal remote.
Feb 25, 2015 | Fisher SLIM-1500 CD Shelf System
M-error message on Fisher studio 24 tad-9715 how do you reset or fix this so it will play cd's again
TAKE COVER OFF THERE IS A MEMORY RESET BUTTON ON THE LEFT SIDE ON LOWER BOARD
Dec 21, 2012 | Fisher 9925 Shelf System
Tad-da350 unit sayes no disc in cd player when there is a cd in player?
salut, j'ai un fisher tad da 350 j'ai egare le circuit integre de puissance. Est-ce -que vous pouvez m'aider a trouver son numero ?
Sep 29, 2011 | Fisher DCS-DA350 Shelf System
How 2 unmute without a remote.
Most well-designed units will interpret raising the on-board volume control as a desire to unmute.
Aug 14, 2011 | Fisher DCS-M430AV Shelf System
How do you change stations on fisher da350 no buttons on the radio will change the radio station
Change to Tuner using the Funtion button. Continue to press the MEMORY button until it starts to scan the frequencies.
Jul 19, 2010 | Fisher DCS-DA350 Shelf System
I HAVE A FISHER TAD-9415 SYSTEM AND THE CD WONT
hope it is not too late but have had the same problem, just got around to open up the case and found the problem and was able to fix mine and now it plays fine. My problem was with the cd turn table it was not be feeding the cd into the player causing the m-error..
Dec 07, 2009 | Fisher 9925 Shelf System
Settings
http://www.sanyoservice.com/pdf/images/DCS-C60%20(OM).pdf Its not the same model, but should be the same adjustments.
Oct 29, 2006 | Fisher DCS-S450 CD Shelf System
Technics SCEH790 CD Shelf System Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
