Question about Car Audio & Video
HI I bought a kenwood kdc-mp5032 second hand and i bought and adaptor for the 13 pin port in the back that turns into a headphone jack to plug in my android phone to play music and the head unit isnt registering that there is any aux input, is there any way to remedy that situation or is there a different way i have to plug the phone in or is there no possible way to do so any help would be appreciated thanks.
  • 65 Answers
Must make sure it is support Aux in, you can try to source change. see whether you can see AUX In at the display? looks not support
Posted on Nov 28, 2013
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
SOURCE: turn aux on on kenwood kdc-mp205
In order to access the AUX option the stereo needs to be in Standby mode. To do this just hit the SRC or source button until you reach the Standby option. Now hit the menu button and scroll up or down until you reach the AUX on/off option and just turn it on. Hope you find this helpful.
Posted on Oct 28, 2008
SOURCE: Accessing aux port on Alpine CDE 9881
If you happen to have the tool which allows you to remove your head unit from the dash use it. If not go to crutchfield.com and get one it's useful for any audio enthusiast. Once you have the tool pull the head unit out on the back of the unit there is a cable that is black with a blue connector tip. This is what you plug your cable that you got from your audio dealer into. As for making the cable accesible you may have to drill a hole in your dash or run the wire around and out the glovebox which is also common and suggested for your particular car.
Posted on Jun 11, 2009
SOURCE: Can;t play my Ipod through Kenwood KDC 237
i was just having this same problem but i pressed standby and menu and scrolled up till i got to a AUH which is off all i did was turn it on and press standby again and my ipod started playing
Posted on Jul 06, 2009
  • 18 Answers
SOURCE: I can't play my iphone on my kenwood KDC-MP435U
Jennifer, I have the same issue. the problem is that the 2007+ generations of Kenwood receivers are not compatible with the iPhone. You will need to get a 2009+ series in order to use your iPhone with the head unit. I had the same issue with the Kenwood KDC-MP435U in my mustang. I am going to get a newer head unit that supports the iPhone. You cannot do it with the MP435U.
Posted on May 30, 2010
Kenwood kdc-mp5032
como le hago si no tengo el control como configurar
Mar 31, 2013 | Kenwood KDC-MP5032 CD Player
Does the Kenwood KDC MP5032 have an aux input? If so, where is it?
Kenwood utilize the CD Changer plug in the back (which acts as a secondary Aux input), to operate external iPod devices.
This is done with the aid of an Adapter Lead - it has the 13-pin DIN plug on one end (plugs into the rear of your unit), and an iPod plug on the other end (plugs into your iPod).
Depending on the "Generation" of your external iPod device, you will need to buy the appropriate Kenwood adapter cable. These are: KCA-IP102, KCA-IP202 or KCA-IP302.
There may be some aftermarket (3rd party) cables that may do the same job.
Just ensure you read your Kenwood manual, as the Kenwood unit may be limited to the types of files (i.e. formats) it can read & play.
Hope this explains....
Cheers,
Dec 31, 2012 | Kenwood KDC-MP5032 CD Player
I bought a used car and it already had a kenwood kdc-x890 installed. my question is when i plug my zune or even just a mp3 player into the usb port it responds with [n/a data].
The KDC-X890 will play MP3s that are stored on a USB mass storage device, such as a USB thumb drive. It won't play music from another MP3 player such as a Zune through the USB port, but you could plug your MP3 player into the auxiliary jack.
Mar 04, 2011 | Kenwood KDC-X890 CD Player
IM TRYING TO MAKE MY OWN HARNESS FOR A KENWOOD KDC-MP5032 AND I DONT KNOW WHICH WIRE GOES WHERE. PLEASE SEND ME ANY INFO YOU CAN. THANK YOU FOR YOUR TIME!
the usual colours are:
  • black - ground
  • blue - power ant
  • blue/white - remote power on
  • yellow - +12v
  • red - accessory
  • orange - illumination
  • white - left front
  • gray - right front
  • green - left rear
  • purple - right rear
on the speaker ones the colours with a black strip are usually the negative -
hope ths helps
Sep 21, 2010 | Kenwood KDC-MP5032 CD Player
How do i set the clock on my kenwood kdc-mp5032?
press the menu button for a few seconds until the menu comes up, then using the am or fm buttons scroll until you reach clock, then press either the seek up or down button untill display flashes. then press the am/fm buttons to set hour and seek up or down to set minutes. when finished just press the menu button againl.
Dec 09, 2009 | Kenwood KDC-MP5032 CD Player
Is there any ipod interface that can support an iphone into a kenwood kdc mp5032 deck ?
You can buy a thing(not sure of exactly what its called) that you plug into your iphone and you pick a radio station on it and turn your stereo to that same station and listen to your itunes
Nov 27, 2009 | Kenwood KDC-MP5032 CD Player
Kenwood kdc-mp5032. cannot play car stereo. unit requires code when powered up. current known code doesnt work.
Unfortunatel KENWOOD codes are not available for free from anywhere on the Internet.
Main Dealer or a Decoding Service only
Sep 01, 2009 | Kenwood KDC-MP5032 - Car Audio CD MP3...
Ipod
On the Kenwood models that are within about 6 or 7 years old or newer, there is an iPod adapter for the head units that plugs into the CD Changer port on the back of the radio. Kenwood makes an adapter (KCA-IP500) that gives direct control and charging through the radio and several companies make aux input adapters for Kenwood radios that will connect to the iPod's headphone jack.
Sep 21, 2008 | Kenwood KDC-3024 CD Player
Ipode
The problem is that Apple rewired the USB port on both the ITOUCH and the IPHONE. hey've made it an Apple only connection now . Run out of your headphones to the AUX in on radio
Mar 08, 2008 | Kenwood KDC-MP435U CD Player
I dont have a remote but i can.t sem to get past the code an i dont know the code
well i have the radio kdc-mp5032 an i have the remote but its askin me for a code an the place that i got it installed at closed down an i dont got the code any more how code i unlock my radio code
Jan 06, 2008 | Kenwood KDC-MP5032 CD Player
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
