Question about Philips HTS3450 System
No Disc After inserting a DVD, the LCD screen shows "loading" then "no disc". I have unplugged for 2 minutes and have also tried various DVD's that all have worked prior with no success! Have even used canned air to blow out any debris that may have collected inside. System is barelly over a year old.
  • 6 more comments
  • lampertj Dec 11, 2007
    Same problem here, no "dirt" on the lens as far as I can tell. Worked one day, didn't work the next. Argh!!!
  • bonnieb Dec 27, 2007
    After inserting a DVD the machine will whirr for a few seconds while displaying "loading" and then "no disk will display. At first this was random happening maybe 25% of the time and now it is permanent. and does not matter which disk I insert. The system is barely a year old if that.
  • Anonymous Feb 06, 2008
    exact same problem froze halfway through a movie now won't read DVDs. but WILL read CDs fine!
  • Anonymous Jan 31, 2009
    I have the same problem tryed to clean it doesn't work somebody help!!!
  • Anonymous Feb 01, 2009
    After putting in dvd it shows loading, then no disc
  • Anonymous Mar 04, 2009
    I HAVE SAME PROBLEM
  • JOYESH Mar 04, 2009
    NO Disc" problem, and notify you when a new solution is offered.
  • Zak Munch Jan 15, 2012
    Did anyone find a solution to the Bose 321 problem of not playing any DVDs only CDs?
Posted on Mar 04, 2009
  • 93 Answers
It could be some dirt & dust on laser lens. Did you try to clean it?
Posted on Oct 11, 2007
I put a DVD in my Digitec DVD player. it says Loading for about 2 minutes and then says no disc with all dvd's but it worked less then 24hours ago
try to open the case of your DVD player, insert the DVD disc and then see if the disc is spinning and loading, otherwise the optical DVD laser lens is weak.. you have to replace it.
Aug 14, 2010 | Televison & Video
My built-in dvd will not work.
hello,
The most common reason for the system not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your system including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your system going again!
Hope this will help....
May 30, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
When I insert a dvd it says no disc
DVD need replesment of optical lens,then its ok
Jul 09, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Disc Error message
UNPLUG UNIT AND LEAVE OFF FOR 1 MINUTE. THEN PLUG BACK UP AND RESTART
Mar 17, 2008 | Sony RDR-GX300 DVD Recorder
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Philips HTS3450 System Logo
284 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
