Question about Toshiba 42HL167 42 in. LCD Television
Regza 42XV540U won't turn on - Toshiba 42HL167 42 in. LCD Television
Won t turn on
What model is it ? Explain "Won t turn on ".
Aug 31, 2014 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do i remove swivel base from toshiba regza 42xv540u
Make sure you check the owner's manual. You can probably get a free download if you lost yours.
Some TVs have screws on the backside near the bottom, not just underneath.
Jun 17, 2014 | Toshiba REGZA 42XV540U 42-Inch 1080p 120Hz...
Toshiba Regza 55zu655u won't turn on no lights
If its total dead with nothing suspect the fuse the power cord goes to inside the set, if other let me know what it is doing or not doing in more detail.
Dec 04, 2012 | Televison & Video
My Toshiba regza television won't turn on
A model number would be helpful but in general if the red light just blinks the set is in shutdown since some error or problem has been detected.
Jun 03, 2012 | Televison & Video
How do remove the base on a toshiba 42XV540U?
toshiba 42xv54ou it wount trun on and it blink a yellow light three times
Dec 06, 2009 | Toshiba REGZA 42XV540 42 in. HDTV LCD TV
I have a 52in Toshiba flat screen that I want to take the base of of so that I can mount it on the wall. The model number is 42XV540U.....I have removed all the screws from the bottom of the base of the...
Check carefully with a flashlight to see if you removed all the screws completely. The stand should pull out quite easily as long as all the screw are out on the back bottom center of the TV.
Nov 09, 2009 | Toshiba REGZA 47HL167 TV
Toshiba regza 46rv530u will not turn on
Check the ac fuse. In a couple of cases because of a power surge the fuse opens up.
After replacing, the sets have worked normally.
Jun 17, 2009 | Toshiba REGZA 46RV530U LCD TV
Regza 42" TV and DVDs
select the right setting in the menu
Oct 27, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Toshiba 42HL167 42 in. LCD Television Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
