Question about kawasaki PVS-10921 Portable DVD Player
Where can i buy a battery pack, model no. batt-2p
4 Suggested Answers
SOURCE: Have 5 batt-2p batteries 7.2 volt for a pvs166w
where did you get the batt-2p. i need one badley
Posted on Dec 04, 2008
SOURCE: Need charger for Kawasaki portable DVD player
Bob have no charger but do have 5 batteries.
dizzyconnors@sbcglobal.net
Posted on Jan 25, 2009
e-Guru
  • 3917 Answers
SOURCE: cannot find a new battery batt-2p
Please check this links bellow for the battery, hope it helps:-
http://www.mdsbattery.co.uk/departments/department002.asp?Brand=KAWASAKI&DepartmentName=Portable+DVD+Player+Batteries&DepartmentID=184
http://batteries.batterymart.com/kawasaki-portable-dvd-player-rechargeable-battery--list
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Jan 01, 2011
Mkbl1830.blogspot.com
There are battery shops around the specialise in replacing the batteries in the battery packs. Normally around 1/2 price with much better quality batteries than original. Remember when buying a portable unit then most of the price is in the battery pack so the cheaper the item the lower quality of the batteries used. That is why you are offered 2 packs sometimes as they are of low quality but you consider it a bargain
Jun 25, 2013 | Drills
Need a battery- BATT-2P for DVD player-Kawasaki PVS1080
The battery is difficult to replace, I cannot find any after market batteries to replace your current one.
You can try buying a generic battery "extender" see here
I have used these in the past and they have worked well.
Jan 25, 2011 | Video Game Consoles & Games
Battery Packs for Powerware 9355 UPS
The Batts can be charged externally, then refitted, usually I extend the DC cables so I can work with the batt outside the unit. This is ONLY to be done if you understand the risk and what may happen if you get it wrong.
Batts are always live and can cause fire/explosion/severe burns if shorted!
IF YOU ARE NOT SURE THEN GET SOME EXPERIENCED HELP!
OK so the UPS will not normally recognise a very low batt pack, that is the reason you can not start the test, this test will back of the rectifier so the batt pack takes the load for a short period.
If the batt pack is out of range then this will make the load go off, so the UPS is designed not to allow the test,unless the batt is at the right level.
If you can get the batt pack up close to normal then the unit will recharge it to full.,Wait until it is fully charged before testing.
If this is sucessful the cyle the batt a few times allowing it to reach around low batt warning before recharging. This will assist the batt in recovery. During this process if possible monitor with a test intrument(fluke 123 or 43B will do) the batt pack discharge curve , once the batt pack has dropped to its charge level from float, it should be a smooth decay.
depending on the state of the batts you may be ok, if there are weak ones in the string then you may have to replace all of them depending on the age of the batt pack.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Feb 03, 2010 | Powerware 9355 UPS System
We have managed to lose the rechargeable battery pack. Where can I get another one?
Oh my, not good. Well, you do need a battery pack. Contact the MFR for replacement pack via customer support, or check the voltage on the side, if using 9V, get a battery holder that uses 8 batteries[2 Xtra cells are used to disable the shutting off at too high a voltage due to the missing battery pack]go to battery space.com, and go to wires/connectors, and get the laptop connectors to make an external battery pack. Therte is a battery pack charger/I recommend accupower evolution. You have to google and go to other sites to get the rechargeable batteries and battery holder. You can get by with alkaline, but they would go rather fast due to the large screen size. You need that good brand name so they can be evenly charged due to the batteries being able to be run down further. You wont be wasting much voltage with alkaline due to the lower cutoff voltage, but 1st try contacting the mfr or googling to get that battery pack!!!I Hint: if using battery pack and you still want to add more battery life, drop the batteries to 6 on a 9V circuit. with original battery pack on, a 9V circuit would use 6 D cells on an external pack, 8 for a 12 volt.
Aug 17, 2009 | kawasaki PVS-10921 Portable DVD Player
Battery pack
I don't know if this will work but it worked for my PowerShot A300.
Take a pencil eraser and clean the battery connections inside your camera. Just be sure not to let any eraser flakes inside the camera.
The Canon rep indicated it would work for the A300 ... Not sure why it wouldn't work with yours as well.
Good luck.
Aug 29, 2008 | Canon PowerShot SD870 IS Digital Camera
WEBCAM
i have lost my ZSMC USB PC camera driver, its model is 2P. now i am unable to use cam. pls help me for download this driver
Jul 28, 2008 | Logitech QuickCam Express 5-Pack Personal...
Batt
Check http://www.batteryvalues.com/ or do a Google search. There are several online battery suppliers. Note: You should be able to find a specific battery number on the battery pack which will help to ID an exact replacement.
Nov 28, 2007 | Jwin JD-VD736 Portable DVD Player with...
kawasaki PVS-10921 Portable DVD Player Logo
27 people viewed this question
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
