My Bosch Washing Machine Maxx 5 1200 started to smoke from the drum and small like. Burning rubber. It was on a qickwash programme..Do you know what the fault is ??
2 Suggested Answers
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Machine doesn't take enough water where and how can I adjust the amount of water in the drum it's a bosch maxx WFL1200
Locate the water level switch at the back inside
it is a round plastic unit approx 60mm dia with a rubber hose and some wires
you will find adjusting screws on it
Jan 18, 2015 | Bosch Washing Machines
Bosch Maxx wfl 1300 washing machine - drum making loud squeaking noise.
sounds like bearing have failed or the stainless steel drum has detached from its carrier open the door and try to move the drum up and down there should be no movement at all if there is machine will need to stripped down
Mar 03, 2014 | Washing Machines
Smoke washing machine drum
the motor might have burned out have a tech t check this out
Jan 27, 2014 | Bosch Washing Machines
We've been given a spare Bosch Maxx 900 washing machine by friends which hasn't been used for a few years. Have plugged it in, connected the hoses, and switched it on for a standard cycle 40...
Hello is this a front loader machine and if so in the back of the machine there are 4 bolts that go thru a 3' piece of plastic. they should be around the drum area they use these to keep drum stable while being transported so look for them. Hope this helps you out
Jul 21, 2011 | Bosch Washing Machines
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
Jan 20, 2010 | Baumatic BTWM4 Front Load Washer
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
