Question about Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine
Water keeps running on cm3
Only will harvest if power is reset.
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Replace the ice thickness sensor hanging on the front of the evaporator plate. when you turn the power off and back on factory default is to go to harvest first. if the ice thickness sensor dose not sense the ice is thick enough then it will not go into a harvest. before you replace the sensor take it loose from the evap plate and drop it into the water sump tray if it goes into a harvest then replace the board. if not then replace the sensor.
Posted on Sep 26, 2014
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
How to get ice going
First is the machine making ice ? If it is making ice is it thick enough so the water comes in contact with the ice thickness probe. This has to happen so the machine will know it needs to go into a harvest. You should not have to fores it into a harvest it should be doing it on it on. There is a harvest button on the CM3 controller but when you push it its going into a harvest and when it finishes the harvest it will shut the machine OFF. I really need more info. What is it doing or not doing?
Mar 19, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman CM3 does not harvest and does not refill
Remove the ice thickness probe that is hanging at the top of the evaporator plate and clean really good put it back push the freeze tab. If the ice is still getting to thick and not causing the machine to go into a harvest then replace the probe , make sure when you do this to set the thickness by using a 1/8 inch drill bit, lay the bit flat between the evaporator plate and the probe turn the 1/4 screw in or out to achieve the 1/8 inch. The probe is what sets the machine into a harvest, if the ice is not building up enough to cause the water to come into contact whit the probe long enough then it will not go into a harvest. if the ice is getting to thick and the water should be running over the probe it should have went into a harvest if not then the probe is not sensing it to tell the CM3 to go into a harvest.
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cm3 does not harvest
First i need the model number CM3 is a controller number and is it a blue or black controller. then i will be able to help you.
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
Ice machine harvest two times and shut off
These unit time freeze time and harvest times and keeps track of them. If your freeze time exceeds 35 minutes or harvest time exceeds 3 minutes, it will place unit in lockout. The biggest cause for excessive time to harvest is the harvest valve not functioning properly, and undercharged unit or a dirty condenser. The most probable cause is a dirty condenser. Under charged units can be determined by checking compressor outlet temperature while running, it should be 150 to 190 degrees depending on atmospheric conditions present. If it is harvest valve, the downstream temperature will stay at or near compressor discharge temperature. It should cool down to ambient temperature in a few minutes after freeze cycle begins.
Nov 25, 2013 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman cme1356 stays in harvest too long
First make sure the machine is clean and sanitized. Also make sure the harvest assist plunger is engaging. Is the hot gas valve opening up? is the pump running water over evap plate.
Aug 09, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Refrigerators Logo
Top Scotsman Refrigerators Experts
john h
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
