Question about RTO Drills
Jcb cordless replacement batteries
Find a replacement battery for my JCB 21.6v cordless drill
4 Suggested Answers
SOURCE: My JCB 18V cordless drill is not working when you
It's probably the switch; mine judders and works kind of. Slight burning smell coming from it, dismantled it to discover that the switch has started to burn out, so far no luck finding a replacement.........
JCB are totally useless, no help from their support phone number!
Posted on Jun 11, 2011
  • 87 Answers
SOURCE: The switch in my JCB cordless drill is starting to
Before you look for a replacement of switch try first to checked the connections of switch if it is OK,then try to cleaned the contact with it.,If you are know how to used a tester try to checked the continuity of the switch, by placing the test probe of the tester to the 2 wire of the switch then from the tester select sound continuity,(one test probe to one wire) it should hear a sound from the tester,it means the the switch is good. Hope this simple solution could help to solve your problem. Don' t forget to rate me up sir/madam.Thanks.
Posted on Jun 12, 2011
99rannellis
  • 10239 Answers
SOURCE: I have a Craftsman 19.2 volt cordless drill I need a battery and a charger for it battery number 13013 for one and the charger is 1401 733
Sears would most likely have it or can order it for you.
Posted on Jan 10, 2017
Jcb sds chuck repair
Allways In a bench vise not allways a demolition hammer has a chuck but most times a locking sleeve for sds but allways you can remove it .
Apr 30, 2014 | Hammering
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
Jcb 530/70 won't start.turns over fine,changed
you should check your battery at first!!!
_____________________
bmw b800
Jun 11, 2012 | Cars & Trucks
The switch in my JCB cordless drill is starting to die. The rest of the drill is perfectly fine, motor etc. I have tried calling th JCB support number, however they were no help. Any ideas where I can...
Jun 12, 2011 | Drills
Gauges don't work, battery goes dead, ignition changed, battery changed, alternator changed problems presists
Charge battery, start engine, then touch the small terminal on the altenator momentarily with a jumper lead from the hot terminal on the alt. Charge light should go out and batery should be getting a charge. why it does that i still can't figure it out, but it works!
Nov 24, 2010 | Jcb Bruder JCB Loader Backhoe
My JCB 18V cordless drill is not working when you press the trigger. The battery is fully charged any ideas please.
Sep 15, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
Which type of oil goes in the chuck of the jcb
use 3 in 1 oil, its light and wont hold a lot of dirt or gunk. easy to clean chuck and reapply
Jun 10, 2009 | Drills
Drills Logo
114 people viewed this question
Top RTO Drills Experts
Are you a RTO Drill Expert? Answer questions, earn points and help others
