Question about Nespresso Coffee Makers & Espresso Machines
Delonghi lattissima en 520 latte and cappuccino lights flashing
After descaling the milk frothing stopped mid cycle now both the latte and cappuccino lights are flashing and milk frothing will not work. Coffee functions still work?
SOURCE: Why won't my starbucks serina froth milk. Just
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Posted on Dec 02, 2009
Testimonial: "This was totally helpful. I thought I had tried everything, Thanks very much."
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: There is no milk coming out of the frothing part
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
Posted on Jun 21, 2010
SOURCE: I have just bought a Delonghi 680M. When I press
The coffee machine has standard settings for each program. What you seem to feel is not enough is the standard setting for Latte. You can always set it to your desirable quantity, either for milk or for coffee.
Refer to your users' manual for more :)
Posted on Aug 03, 2010
  • 7 Answers
SOURCE: Delonghi Rialto 4500. The milk doesn't go trough,
I fixed this problem on my Magnifica by gently scraping the scale away from the inside of the coupling (clearing the hole of scale and debris)
Posted on Aug 07, 2010
Delonghi perfecta milk not hot enough
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Which kind of plant-based milk is best to make cappuccino?
One can use many types of plant based milk for making cappuccino. It can be soy milk, almond milk, coconut milk, chia milk, hemp milk, rice milk, oatmeal milk, hazelnut milk or any other.
According to my taste, I always use almond milk to make a cappuccino as it provide a great taste and flavour to the cappuccino.
Jul 03, 2013 | Wine & Spirits
Delonghi Lattissima EN 660CW milk frother not frothing
I don't know why my answer posted in the comments section, so here it is in the proper area.
I had the same problem and was ready to send it in for repairs, but I talked to a great guy at Nespresso who helped me fix it myself. The problem was when I pushed the latte button, it would only froth milk for a second or two and then the espresso would start pouring. It basically refused to make a latte. Here's the things he had me do:
1) Descale immediately. I have an older machine, and descaling once a year does NOT cut it. He told me descaling every 5 months at the bare minimum, if your machine is not having any problems at all. Descaling is usually the main problem for lack of froth. I descaled and it seemed like the machine was working better almost immediately. I also ran 4 - 5 tanks of water through the hot water spout and the main espresso part (but mostly this is because it seems to take this much flushing to get the smell of the descaling solution out).
2) Reset your machine to factory settings. I have a classic Lattissima, so this is how you do it on that machine. Turn the machine on and wait until the drink buttons are steady (espresso and hot water buttons are no longer blinking to warm up). Then press and HOLD the power button until the espresso and hot water buttons BLINK THREE TIMES. Then they'll go back to steady again. You're now back to factory settings.
I did notice that I started having the trouble after moving the machine, so I'm not sure which of the above solved the problem. The main thing is it worked and I'm back to yummy lattes!
Jan 09, 2012 | DeLonghi Nespresso EN660 Espresso Machine
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for...
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Leni
Nov 06, 2010 | Krups Cappuccino/Espresso Maker -...
It froth's milk beautifully but won't do soy milk.
We bought a Nespresso Milk Frother in 2010 for $100. The frother is the same one that comes with the Citiz machine but is a stand alone model. It froths soy milk very well. The less soy you put in it, the more froth you get but even if we fill it to the max line we still get a reasonable amount of foam. We use Silk brand soy milk. I have no idea if foaming is impacted by atmospheric pressure but it may be a factor to consider if you are using all the same factors as us but not getting great results. We live at a higher elevation Calgary, Canada in the foothills of the Rocky Mountains.
Sep 15, 2010 | Nespresso Aeroccino Automatic Milk Frother
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
I have just bought a Delonghi 680M. When I press latte not enough milk flows out. The cup only fills up about 2 inches and then the coffee pod starts.
Dec 06, 2009 | Nespresso Lattissima 660.R
Coffee Makers & Espresso Machines Logo
151 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
