Question about Maytag MZD2766GES Side by Side Refrigerator
GE PROFILE SIDE BY SIDE water line tube
Plastic water line cracked from bottom of ref. to the top upper cornor feeding to the ice cube trays. I bought new plastic tubing but im having trouble connecting the tubing to plastic nut at the question is do I have to buy a FIX GE tubing that is attached to the plastic screw?
  • 473 Answers
Sounds like you are talking about the plastic nut that screw onto the water valve. That nut should just pull off. May have to pull kind of hard then just push onto the new line. Is this what you are talking about? Let me know.
Posted on Oct 10, 2007
  • Craig Shelton
    Craig Shelton Oct 10, 2007
    Also, the new water line must be the same diameter.
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Home from vacation--no ice.
Check the fill area of the ice maker for an ice blockage.
- make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
- check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
- Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
If your icemaker is the common one there here is a way to test it:
(I noted GE Profile but not an exact model number)
Last question... does water in door work?
Thanks for using FixYa.
Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
I have french door with freezer on the bottom refrigerator in the GE profile line. I have the internal ice cube maker. My ice cubes melt into one big block of ice. I lowered the thermostat to -5 but that...
check ur temperaTure in the freezer make sure it is 5 degrees fahrenheit or lower if it is u might need to see if ur ice maker tray has a crack i it to where when the water goes in to be frozen it runs out a crack and if all this is good check to see when the ice maker fills up its just not running over
Mar 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker on side by side refirgerator will not quit making
Hello there
Please try these few tips ok?
  1. It may be turned off. Check the Ice maker shutoff arm located at the top of the ice bin. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, simply lower the wire.
  2. Is there water in the ice cube tray? If not check for water to the water valve. If you have water then it could be either a failed fill valve or ice maker control module is not activating the water valve.
  3. Check for pinched water supply line (behind the fridge)
  4. Do you have an inline water filter? If so, when was it changed last? To test if it is plugged, check for water both before and after the filter system.
  5. Sometimes the water inlet tube that directs water into the ice cube tray freezes over; this can often be thawed out by simply using a hair blow dryer and warming the area (be careful not to overheat the plastics as they can warp or crack). Then adjust the freezer to a slightly warmer setting and make sure water is not constantly dripping from the inlet tube, as it will only freeze over again.
  6. If it continues to drip we may need to replace the water control valve.
  7. The ice maker head assembly may have broken parts. Look to see if the gears are broken.
  8. Check to see if the small plastic arms that rest against the ice rake are broken.
  9. If the ice maker head assembly is modular and you've found broken parts,
Nov 08, 2009 | GE Refrigerators
GE Ice Maker that leaks water down the freezer wall
Ice makers have limit switches, thermal temp sensors, heating element and if anything gits out of order with these parts they will begin to do strange things like that. Now if you would like to remove it and have a look at the internal parts you may find the problem. They are a little easy to loose parts so be careful if that's your choice. A series of about six different cycles happen when they fill until the time it empties and begins again. They may cost less if you don't see what wrong to purchase a new ice maker. If you would like more help feel free to ask, Thanks, Sea Breeze
Apr 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator slow to make cubes
I had the same problem with mine a month ago. The plastic feed tube to the water solenoid valve was cracked and letting a large portion of the water go under the fridge on the floor. I just cut the cracked tubing off at the valve/fitting area and inserted good tubing into the fitting and tightened it up, it has been perfect since!
Dec 05, 2008 | Refrigerators
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
