Question about Mansfield Plumbing Products Mansfield QUANTUM White Round Front Pressure Assist Two-piece Toilet with S
Mansfield pro-fit 3672 won't turn off
Whirlpool will not turn off with air switch or low water sensor. I need to turn it off at breaker
Jets will not turn off
Sounds like your air switch is bad in the little box on top of the motor.
It is part # TBS-339
Rod
US Parts Center
888-521-6183
Apr 25, 2013 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
My jacuzzi bath tub will not shut off.I have reset the breaker, blown out the plastic line and air is coming out the other end but still wil not shut off. We have only used this tub 2 or three times. Any...
It sounds like your pump in turning on/off with an air button on the top of the tub.
The pump not turning off could be either a bad air button, not sending enough air through the tub to operate the air switch in the motor or it could be a back air switch in the motor where the air hose attaches to it.
Take a large straw and blow into the air switch and see if you can operate the air switch on/off.
If it will turn on/off then you know you have a bad air button on the tub however, if you cannot get it to turn the pump on/off then you know you have a bad air switch in the motor.
Rod
US Parts Center
888-521-6183
Feb 26, 2013 | Home
My jacuzzi has one wall timer that says set after 10 minutes marker."turn past ten then set time" There is one button on the far right corner that depresses. I am a clueless tenant. How do I...
There are a couple things you can try with your tub.. The 10 min timer is one they used on older tubs but, may still be used with yours. Turn timer all the way up. make sure tub is filled with enough water. some have little sensors that wont let it turn on with out enough water. The button may feel spongy because it is using air to turn on the pump switch so give it a good quick push.. also the last things to check will be to check the breaker box and be sure the breaker is on, turn the breaker off and on to test. also look around the room of the tub and look for gfi plugs and switches that may be tripped. they will look like the wall plugs for hair dryers but, may not have outlets on them. just reset all plugs you find in the rooms. Hope this helps you. ask more questions if you need to.
Feb 09, 2011 | Jacuzzi EE10 Luxury Bath Bellavista 5...
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
The 60 second light is flashing on thermosol one touch control indicating low water sensor is activated. turned off breaker to reset still flashes. steam will not come on.
Did anyone answer your question about the 60 minute light flashing? I have the same problem and have also reset the breaker but have the same problem :-(
Dec 22, 2009 | Thermasol Steam Bath Generators - Ambiance...
Connecting a mansfield whirlpool tub pump don't know the model number pump is in the floor and tough to get to. there are 2 cords hanging out. 1 male end and 1 female end. When I plug in the male end, the...
Hello Joe, Typically when you have a whirlpool type tub, there is either a built-in air switch on the tub that will turn the tub motor, on and off, or the tub needs to have a wall switch to turn it on and off.
The switch has to be located so it is at least a minimum distance of 3-4 feet from the edge of either a tub or shower stall, and it must be connected to a GFCI protected circuit. Normally any whirlpool tub requires a separate dedicated 20 Amp 120 Volt AC circuit for proper operation and to meet code.
I believe that the female plug is for an optional, in-line heater that can be installed into the tub unit. You should be able to check the installation manual that came with the tub to verify the proper wiring required for your specific unit and model.
I would contact the manufacturer to get a copy of the installation guide and instructions for your model, so you are certain that it is properly installed and the wiring you are using meet the NEC (National Electric Code).
Here is a link to the Mansfield web site with some FAQ's and their phone contact information.
http://mansfieldplumbing.com/v3/support02-03.html
I hope you find this Very Helpful and best regards!
Dec 11, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My Kohler whirlpool started on its own with no water in it. We turned it off with the switch and it hasn't happened again. Is there a danger of it starting a fire if we are away from home and it does it...
Most Kohler tubs have a water sensor or water level sensor. Is this an air bath tub (holes in the floor)? or a jetted tub? If it is an air bath, the tub will purge after using it 15 to 30 minutes ater it is drained. If it is programable it will come on every 24 hours if it has been programmed. If it is a jetted tub, there may have been water on the sensor and caused it to start up. If it is a single on/off button the switch could have gotten water and caused it to start up, or there is a problem with the control box. It usually will not start a fire if it comes on, most of the newer pumps have run dry seals. If you leave the house for vacation or weekends, I would advise unplugging the tub or turning off the breaker.
Aug 28, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Mansfield Plumbing Products Mansfield QUANTUM White Round Front Pressure Assist Two-piece Toilet with S Logo
37 people viewed this question
Top Mansfield Plumbing Products Home Experts
jdthefixer
john h
bobalix
Are you a Mansfield Plumbing Products Home Expert? Answer questions, earn points and help others
