Question about Canon PowerShot A530 Digital Camera
Zoom won't work
I have a Canon powershot A 530. All of a sudden the zoom won't work & the menu buttons won't work either. I have tried to change the batteries, take out hte memory card, turn it off & on... but nothing works. i can still take pictures & change the setting wheel at the top but that's it. Do you know how to fix it???
  • 1 more comment
  • choubey Nov 22, 2007
    I've the Canon Power Shot A 530 Digital camera, i'm facing the problem of zoom is not working during video shooting. But it is working in still photography. I had replaced its Battery but the problem is still there. Kindly suggest the solution.
  • Annecam Jan 20, 2008
    I am having the very same problems with my A530. I'm a bit upset and cannot afford a new camera!! If anyone has a solution, please let me know ASAP! THANKS! ARC January 20, 2008
  • bozons Mar 09, 2008
    exact same problem. camera turns on, but zoom and menu buttons don't work.
I have had the exact same problem develop with the A530- now twice!
The first time I had to send it back to Canon to fix it. According to the repair summary, what they replaced was, well, the entire control board...not many things breaking can cause the entire zoom/buttons to stop functioning aside from a control board malfunction of some sort.
Anyways, Canon fixed the camera, everything was hunky dory.
For six months. Then the problem developed again. When the same problem occurs twice in a row without any warning whatsoever, that's when I start getting annoyed and consider buying another camera.
So at least in my case, the solution to the problem was that it had to go back to Canon for repairs. I had an extended warranty on my camera, so I can't say how much it will cost to repair the problem. If it happens again like it did in my case...consider buying another camera.
Posted on Mar 11, 2008
SOURCE:
The camera (Powershot S5 IS) suddenly quit working. It will not power on (tried two sets of fresh batteries). Am I overlooking something very simple? Is it related to the small button battery that...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Aug 11, 2011 | Canon PowerShot S5 IS Digital Camera
Canon powershot SD870 IS. Once I switched to magnified image playback, I cannot cancel & return to single image playback. Have tried MENU and turning zoom button back.
Problem with firmware [software} ,Please update .
http://www.usa.canon.com/cusa/consumer?pageKeyCode=contactUsLanding
Yo can restart.Replace battery.
Mar 24, 2011 | Canon PowerShot SD870 IS Digital Camera
Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
Jul 01, 2009 | Canon PowerShot G2 Digital Camera
Digital zoom using powershot sx10is
On shooting mode, press MENU,then move down to Digital Zoom. Use right or left buttons to change the digital zoom options. For example: you can set on 1.6x, 2x, etc.
Jun 06, 2009 | Canon PowerShot SX100 IS Digital Camera
I have a Canon Powershot sd1100, it suddenly stopped focusing.
did you set to Macro, change to Infinity. or goto SETUP MENU, then perform RESET ALL.
Apr 06, 2009 | Canon PowerShot SD1100 IS Digital Camera
The zoom won't work on my Canon A460
Your zoom may be turned off, here is how you can turn it back on:
When you are about to take a picture, press the little menu button, then press down until it says digital zoom, if the little black box is over-top of 'off' change it to say 'on'.
Hope this helps.....and makes sense.
Dec 30, 2008 | Canon PowerShot A460 Digital Camera
Canon PowerShot SX100 IS Digital Zoom
Hey NachesLady,
If the option to turn your digital zoom on or off is grayed out then the mode you have the camera set to does not allow changes to that option in that mode. I would try changing to another mode and see if the option is still grayed out. That being said I would NEVER use the digital zoom feature. All a digital zoom does is electronically crop the image in the camera which can be done easier and better once the images are uploaded to your computer. Digital zoom usually produces images of greatly reduced quality. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 10, 2008 | Canon PowerShot SX100 IS Digital Camera
Can't Access Menu + Zooming in
My advice is the same Tell canon Tech Support- this is it seems a firmware problem not fixable by user,
Jul 11, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon S70 does not work
Canon Technical Support is the next place to go. This is a firmware error- maybe not a correctable problem except by replacement
Jun 15, 2007 | Canon PowerShot S70 Digital Camera
I was experiencing the same problem - I think the Button and Zoom had become jammed down slightly. I simply lightly applied pressure lifting the surround of the button up! My camera is now working perfectly.
Jun 13, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot A530 Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
