Question about Furniture
I need to adjust the drawers on my calligaris sidetable
One end of the table when expanded sags ?
Did you find a solution, mine has done the same?
May 29, 2014 | Calligaris Hyper XR Extendable Dining...
How to disassemble the calligaris planet table
Here is the PDF from the Calligaris website:
http://www.calligaris.com/schede_prodotto/H-A%204005%2001%2000-4.pdf
Feb 11, 2014 | Calligaris 35.5"" Planet Table with...
Calligaris hyper table how adjust level
Manual from the Calligaris website:
http://www.calligaris.com/schede_prodotto/H-A%20416%2001%2001-2.pdf
Nov 19, 2013 | Calligaris XR Hyper Extendable Dining...
Just bought a Calligaris 'planet' table and it wobbles.
Check the legs and frame to see if it is out of square.
Sep 23, 2013 | Furniture
Toshiba e233 photocopier does not coincide with the top margin of the original copy
Top margin??? SEF or LEF
1. If it is the lead edge registration, go to 05 mode and adjust the values of the following...
440 > start > adjust value (for upper drawer margin)
441 > start > adjust value (for lower drawer margin)
442 > start > adjust value (for bypass drawer margin)
443 > start > adjust value (for LCF)
2. If it is the side registration, adjust it from the drawers.
Nov 30, 2012 | Office Equipment & Supplies
How do I adjust top drawer height? The seal around top drawer appears to be leaking and there is a lot of dried residue around the top edge of the drawer. Water appears to be leaking from the top.
Not sure if adjusting top drawer height will fix the leak. The only way to fix the drawer seal leak is to take the drawer out and check what is wrong with the seal which is located around the top edge of the cabinet from inside.
Hope this helps. Please rate this solution if helpful otherwise please post a comment
Sep 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Meat keeps freezing in my meat drawer.Any thoughts on how to adjust the settings
There may be a separate control for the meat drawer down where the drawer is. If not, you use the fridge temp control. Make sure the vent between the freezer and fridge is opening and closing when you adjust the temp.
Oct 17, 2009 | Kenmore Refrigerators
Fisher Paykel Dishwasher Door Open error code
If it is a dish drawer type there is a clip at the rear of the drawer that holds the drawer closed. you will need to withdraw the drawer partially to look in. with the drawer open the fingers should be facing towards you. If not you will need to reach in and pull the top of the fingers towards the front. there is a replacement arm that holds the pipes and cables away from this part.
Nov 18, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
Furniture Logo
733 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
