Question about Euro-Pro UV205H Bagless Upright Cyclonic Vacuum
Part for the UV205
I need a belt for my Europro 205H. The smaller of the two, How do I order one? Thanks
I have a new eureka vacuum AS1101 and the roller brush wont spin. The S belt doesn't look worn. When the clutch is engaged the second smaller toothed belt doesn't run. Are the larger and smaller pulley...
The answer is you small wheel that is burned or melted is a result of having the carpet height setting too low for surface being vacuumed. Because of that, it causes the brush assembly drive to work harder. The smaller of the two wheels has..had a piece of plastic to hold it against the shaft to allow it to turn. It will have melted off and will not spin. The belts and even the other larger wheel will work, but just not engage the smaller and allow the brushes to turn. The part needed does not sell by itself, you would need to purchase the on/off wheel assembly. OEM Part # 84708. It is about $30 on amazon shipped. new-eureka-vacuum-as1101-roller-brush-imoup3n5z40rufpnmkir3rab-3-2.jpg
Jul 17, 2014 | Eureka SuctionSeal Bagless Upright Vacuum,...
Re my Sears 3" belt
What did you use to make is smaller (to shrink?)
Is the back of the belt cloth or paper?
Dampness usually makes things stretch--
But too much moisture, and you tear easily, too!
Tell me more-
Mack B
Jul 04, 2011 | Vacuums
Is it possible to download a manual for my recently purchased used Shark Intelli-Sew Europro Model 9110 sewing machine? Thanks in advance for any help you can give me... Kitty...
You could download the same from :-
http://www.sharkclean.com/manual/9110_REV_0104E.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 08, 2010 | Vacuums
Mop pads are wearing and dirty even after machine washing
Yeah, check out the manuals link...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 10, 2009 | Euro-Pro Shark Professional Upright Vacuum...
Windtunnel belt
I've successfully used a compatible belt - Royal 104425001 .It's still new, but for the time being at least - it works.
Jul 29, 2009 | Hoover S3765-040 WindTunnel Bagless...
Need users manual for europro vacuum cleaner model V209AF or EPU2
http://userguides.50webs.com/
You can order and get it instantly from the site.
They carry manuals for every major brand of vaccum.
May 28, 2009 | Euro-Pro Vacuums
I replaced the belt on the vaccum cleaner for the brush and it just seems too loose. How do I tighten it? Do you have a diagram I can look at. I lost my instruction booklet.
try using a smaller belt from a different manufacturer. not to much smaller. you dont want it to be extreamly tight just get one slightly smaller and try that. it dosnt have to be made by hoover. as long as it is not wider or thinner just about the same width and slightly smaller. i do it all the time with my vacuums to save money
Nov 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Euro-Pro UV205H Bagless Upright Cyclonic Vacuum Logo
16 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
