Question about Euro-Pro UV205H Bagless Upright Cyclonic Vacuum
Part for UV205H
I need a new belt for the Europro UV205H, the smaller of the two. How do I order one? Thanks
    Novelist:
  • 126 Answers
I have a new eureka vacuum AS1101 and the roller brush wont spin. The S belt doesn't look worn. When the clutch is engaged the second smaller toothed belt doesn't run. Are the larger and smaller pulley...
The answer is you small wheel that is burned or melted is a result of having the carpet height setting too low for surface being vacuumed. Because of that, it causes the brush assembly drive to work harder. The smaller of the two wheels has..had a piece of plastic to hold it against the shaft to allow it to turn. It will have melted off and will not spin. The belts and even the other larger wheel will work, but just not engage the smaller and allow the brushes to turn. The part needed does not sell by itself, you would need to purchase the on/off wheel assembly. OEM Part # 84708. It is about $30 on amazon shipped. new-eureka-vacuum-as1101-roller-brush-imoup3n5z40rufpnmkir3rab-3-2.jpg
Jul 17, 2014 | Eureka SuctionSeal Bagless Upright Vacuum,...
Re my Sears 3" belt
What did you use to make is smaller (to shrink?)
Is the back of the belt cloth or paper?
Dampness usually makes things stretch--
But too much moisture, and you tear easily, too!
Tell me more-
Mack B
Jul 04, 2011 | Vacuums
Is it possible to download a manual for my recently purchased used Shark Intelli-Sew Europro Model 9110 sewing machine? Thanks in advance for any help you can give me... Kitty...
You could download the same from :-
http://www.sharkclean.com/manual/9110_REV_0104E.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 08, 2010 | Vacuums
Hoover bagless cannister 3765 - belt on power head slips off spindle. bought new belts - same problem. is this a design problem or can it be fixed? I don't want to take it to a repair shop 100 miles...
I would not recommend a smaller belt. You will only wear the motor. This model series power nozzle needs to have a metal clip installed near the belt on the brush roller housing. I know that most of them left the factory without it. Remove the cover to see if one is ther. if not have your dealer send you a clip or a housing with one on it.
Apr 03, 2010 | Hoover S3765-040 WindTunnel Bagless...
Windtunnel belt
I've successfully used a compatible belt - Royal 104425001 .It's still new, but for the time being at least - it works.
Jul 29, 2009 | Hoover S3765-040 WindTunnel Bagless...
Need users manual for europro vacuum cleaner model V209AF or EPU2
http://userguides.50webs.com/
You can order and get it instantly from the site.
They carry manuals for every major brand of vaccum.
May 28, 2009 | Euro-Pro Vacuums
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
I require a new drive belt for my upright vacuum cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698244
Generic problem for all Vacuums
Posted by martiy on Jun 23, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Euro-Pro UV205H Bagless Upright Cyclonic Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
