TCL LED LCD backlight issues - Televison & Video
  • Aimee
    Aimee Nov 24, 2013
    TCL L55P11FZE - Have watched a few youtube videos which seem to diagnose it as a backlight issue. When we turn it on, the picture comes up for a brief second, followed by a black screen. Sound ok. When we shine a torch directly at it, you can see the picture - there the issue is a backlight issue - anything we can do??
  • 4 Answers
First check that the Backlight wire properly inseted ,If yes then check the voltage that comes through PSU to Backlight Inverter Board , If yes then check the all FETs and other components of Inverter Board
Posted on Jan 30, 2014
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
TCL LCD STL308B330 power is on.. sound is ok but no display and no picture . Backlight is in normal
How do you know backlight is normal if there's no display? What inputs have you tested?
Oct 04, 2015 | Computers & Internet
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
Screen is black
This website sells both replacement CCFL backlights and upgrate LED replacement backlights.
update ccfl lcd to led lcd led strip led backlight led kit led backlight...
Dec 04, 2013 | Northstar Explorer 657...
TCL LED LCD 55" - Backlight issues
Repair or replace the backlight.
Nov 24, 2013 | Televison & Video
Is sony klv32-a400a is a led or lcd tv
An LED TV is still an LCD TV, just with LED backlighting. That model is an LCD TV. The difference is in the backlight. Both LED and LCD TVs use an LCD screen. LED TVs have LED backlighting of the LCD screen, which saves energy.
Nov 04, 2013 | Sony KLV32S400A 32 in. LCD TV
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
