Question about Therapure Pool & Spa
How do you deflate a portable spa
Can't find directions to break it down and pack it back up
  • 1,631 Answers
More information is found here...
http://img1.wfrcdn.com/docresources/17631/7/73836.pdf
Posted on Apr 07, 2015
To deflate the portable Therapure spa 050006 is easy. The trick is to realize that the black valve used to inflate is in fact a double valve. Remove the square threaded cap to inflate it.
1. To deflate the spa leave the black square threaded cap and below that you should find a round or winged coupler.
2. Unscrew this coupler off and immediately the air will start to escape. It shouldn't take more than about 2 minutes to deflate and you are ready to pack it away.
3. Return the valve (before doing so you could use a vacuum to suck out as much air as possible.)
4. Lay out the spa floor in a circle
5. Fold the three sides to the centre
6. Then lay the power unit on the folded sides.
7. Remove the coupler one more time to squeeze out any remaining air and then return it.
8. Roll the up the side to the original size of the spa before you opened it the first time.
Posted on Nov 22, 2014
  • davidsparrow
    davidsparrow Nov 22, 2014
My brand new intex spa deflates over night. I have to add air every morning. Should i take it back or does someone know whats wrong?
check for leaks and seal them or exchange it if they let you,put a few drops of soap in a window cleaner bottle with water and spray all connections and look for bubbling,that will be your leak
Jul 22, 2015 | Intex Pool & Spa
How do I deflate spa
Sep 18, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
How to deflate and store
DRAINING THE SPA:
1. Unplug power pack from electrical receptacle before draining spa.
2. Put the rubber plug into the outlet in the inner wall of the spa.
3. Open the outlet in the outer wall of the spa. Screw one end of inflation hose into it.
4. Remove the rubber plug from the outlet in the inner wall of the spa.This will allow water to flow out of the spa. 5.When water is completely drained, press BUBBLE and run for 2-3 minutes to drain the water in the air pipeline. 6.When drainage is finished, remove the inflation hose and replace cap on outside of spa. Store rubber plug for future use.
SPA STORAGE
Make sure all water is drained from the spa and control box.This is essential to extend the life of the spa.We recommend the use of a wet/dry vacuum to blow out or suck up water from the spa pipes and pump lines. Remove the filter cartridge. It is recommended you store the spa in its original package in a warm, dry place.
Note: Plastic becomes brittle and susceptible to breakage when exposed to subzero temperatures. Freezing can severely damage the spa. Improper winterization of your spa may void your warranty.
http://img1.wfrcdn.com/docresources/17478/11/119999.pdf
Aug 13, 2014 | Therapure Four Person Inflatable Round Hot...
Eng 1 code
Hi, if you are seeing an EN-1 code, there isn't any troubleshooting that can be done to resolve it. This code indicates an electrical issue internally, the Power Pack is unable to register the temperature of the water. The unit will need to be serviced. Please contact Oceantis at (855) 772-6269. Oceantis is the only authorized service provider for all of Comfortline Products Spas in North America. Portable Spas Accessories Parts and Chemicals Oceantis Oceantis Cape...
Jul 09, 2014 | Comfort Line Spa 2 Go Portable Spa with...
EN1 On Spa What does it mean
Feb 09, 2014 | Comfort Line Products Spa-N-A-Box Portable...
How do I deflate the spa?
the fastest way to deflate any inflated spa is 1st drain water away , then using a shop vac suck the air from the chambers , it takes but a few minutes to complete that way
take that from guy that's allways in a hurry !!
Sep 20, 2013 | Therapure Four Person Inflatable Round Hot...
WANT SOLUTION ON BLOW UP RIM, PLEASE, NOT FILTER
If this is deflating you should take some soapy water and go around the complete to rim beginning at the seam and locate your Leak.
Rod
US Parts Center
888-521-6183
Mar 04, 2013 | Intex Pool & Spa
Where do I get replacement power pack for spa n a box?
The only place in North America to buy New Power Packs for Spa-n-a-box, Spa2go, Snappy Spa or EZ-Spa is Oceantis in Florida. They also sell remanufactured power packs and do repairs on packs. www.oceantis.com
Feb 10, 2013 | Comfort Line Spa 2 Go Portable Spa with...
Need to buy replacement heater for comfort line portable spa... but have no idea where I can find one. Please help. Motor, heater and pump overheated, and just never started up again, even after it was...
http://www.oceantis.biz/Replacements.html
The above link is for the people who have bought out comfort lines product lines.
There is a link there for the replacement spa pack..
The original manufacturer is out of business.
Pack is about $450 US
Sep 14, 2010 | Comfort Line Spa 2 Go Portable Spa with...
How do you replace a flow switch in a spa, or hot tub
turn off the power to the spa. remove the cabinet under the topside remote to expose the equipment compartment. You should see the flow switch, it's usually a threaded 3/4" plug with a single grey wire coming out of it. Most of them are threaded into a tee or a special transparent fitting. If the water level in the spa is above the flow switch, you may have to drain the spa down unless you're very fast about getting the new switch in. Unthread the old switch and thread the new one in. Follow the wire on the old one to the spa pack. You'll have to remove the screws on the cover to expose the circuit board. Follow that wire into the spa pack to see where on the circuit board that it is plugged in. It may be good to run the new wire to have in place as soon as you unplug the old one you can install the new one with no question as to where it plugs in.
Reinstall the cover on the spa-pack and turn the main power back on. Make sure that the arrows on the new flow switch are facing the correct direction (direction of flow). Once you have the spa on and it starts back up, run everything to check for leaks and proper operation. If the flow switch was the only problem, all your faults should be cleared and you should be in good shape. If there are no leaks, you can reinstall the cabinet panel.
The new switch should already have teflon tape on the threads, if not, use teflon tape, apply the tape in the direction as if you were threading a nut onto the threads. You only need a few wraps of teflon tape, too much can crack the fitting you threat the new flow switch in to.
Nov 03, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
860 people viewed this question
Top Therapure Pool & Spa Experts
The Cover Guy
The Cover Guy
Tom Chichester
J.D. Browning
J.D. Browning
Are you a Therapure Pool and Spa Expert? Answer questions, earn points and help others
