Can sony ta dx8 audio connector connect to output pc
Natahan
  • 24 Answers
SOURCE: PSP sound ouput
I'm pretty sure the USB port is only for transferring media files. I've searched my PSP head to toe and never heard of anything like that. I've found out you can use the USB connector on the white PSP to charge the battery. (I haven't tried that out yet.)
Posted on Dec 28, 2007
Bubbabear64
  • 2794 Answers
SOURCE: ipod 30G video audio output stopped working
There could be something going on with the contacts in the headset jack. If you can get the back of the Ipod off and plug a headset into it, check the two metal pieces on the jack to make sure that the black lines on the plug are in contact with the end of the headset. They can be realigned by simply bending them back into place.
Posted on Nov 17, 2008
joecoolvette
  • 5660 Answers
SOURCE: Require circuit diagram/pin-out for motherboard audio connection.
Kommer,
I believe there has been some misunderstanding. You do not have to pay to receive a free solution. This is only if you need a Premium Expert to give a solution.
You are required to join Fixya in order to post a question, and receive a free solution.
You have already done this.
I would like to answer your query, and provide a possible solution. My solution however, is going to go beyond what you have asked. It is my sincere hope that this provides you an answer to your query, and possibly guidance in what I feel is the ultimate outcome from your question.
I would like you to view this web page,
http://www.systemsalchemy.org/howto/aptiva/bose.html
If this is not the correct response you had in mind, please come back and state so. We'll go from there.
Regards,
joecoolvette
Posted on Oct 08, 2009
Testimonial: "Thanks very much joecoolvette for sticking with me and providing the website address. This information is just what the doctor ordered. Regards Kommer"
smarthome2
  • 1114 Answers
SOURCE: I want to connect my Compaq Presario 2500 laptop
Does your laptop have a VGA port? if so use a VGA cable, the frequency is correct and the picture will be cleaner. The S2000 has PC input. once you have it connected, go to your control panel and select display and look for multiple monitor. It just depends on your laptops operating sys. It can be found in help and support as well. If you need further help, post a comment and I will get you the answer.
Posted on Jan 09, 2011
BElectric
  • 1140 Answers
SOURCE: I am having trouble with
Your connections are correct, it's more likely to be the audio settings on the TV that need to be changed. There is no way of connecting a digital optical audio cable to this TV.
The audio connection you are using between the PS3 and the TV is analog stereo, so the TV audio settings need to reflect this. I suspect you need to the change the Dolby Surround setting for this to work. This can be done using the SURROUND button on the Samsung remote, or from within the on-screen menu.
If this doesn't solve the problem, please go to the SOUND sub-section of the on-screen menu and let me know what the current settings are in this menu.
Thanks,
BElectric
Posted on Feb 13, 2011
I have a Sony TA-AX380 Stereo Amplifier and the accompanying speakers. How do I connect it to my Vizio smart TV? This is my setup.
Most modern TV's have no analogue outputs for sound anymore. Modern surround amps have HMDMI connectors instead or Optical connections. So your amp will not connect without special adaption leads.
Now you have two options, you can use a scart to RCA lead. Or a HDMI to RCA one.
http://latestusb.net/wp-content/uploads/2015/08/micro-hdmi-to-rca-u6y5dcd6k.jpg
Image above. However you must check that you get the right sized HDMI connector for your TV. Although you can get an adapter if you get the wrong one!
The red and white RCA's are the right and left audio. Yellow is video. But you can leave that dangling if you don't need it.
Nov 07, 2016 | Sony Audio Players & Recorders
I AM TRYINGTO CONNECT MY SONY AMP, MODEL # ta-n731 to my sony model# ta-e731
https://docs.sony.com/release/TAN731.PDF
Looks like you need some rca cables to connect the outputs from the e731 to the inputs of the n731. There is also a small 4-pin control cable that connects the units. It probably tells the amp when the pre-amp is on. You may be able to do that manually if you can't find the cable. Or you may be able to make your own cable if you can identify the connectors.
Mar 08, 2015 | Sony Audio Players & Recorders
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
Sony TA-N9000ES Power Amplifier Problem: I have a
I have just purchased a Audiosonic Soundbar KW-3508 and connected it up to an existing cetre speaker connection but could get no sound.Any suggestions?
Aug 04, 2013 | Sony Audio Players & Recorders
How do I connect my computer to my Sony STR-D915.What if any special cable,adapters,equipment do I need to have all computer sound relayed through the speakers I have ?thanks
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts (*) to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
* http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
More-advanced sound cards would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
A digital-capable receiver would accept 44.1 kHz for normal CD or DTS sources. Some diddling with the output sampling frequency might allow digital multichannel audio to be decoded by the receiver.
YOUR receiver has only analog stereo RCA inputs so you
Feb 11, 2011 | Audio Players & Recorders
Trying to connect to LG 60 inch plasma. no output
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Dec 26, 2009 | Bose Cinemate Digital Home Theater System...
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TA-VE100
First of all check for loose connections. Also see if the left front audio output is working or not.
Jul 17, 2008 | Electronics - Others
62 people viewed this question
 Grubhead
Grubhead
