Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
Samsung lcd display lta 320 wt-l05 slow picture
Sony Bravia model LTA 320 -WT-l60 red power LED blinks twice. What does that mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Feb 24, 2015 | Sony Televison & Video
Samsung ln22a450 no picture just audio in the back
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Samsung LN22A450 22 in. LCD HDTV
Olympus re-320 not view the picture
Connect your camera or place your memory card into a computer with image processing software to view picture. Or sometimes if you camera is exposed in a high temperature it may affect the lcd display of you camera. Some camera recovers after long exposure to high temperature if place in a cool,normal temperature. Check also your sd card it might be corrupted also.
Mar 08, 2013 | Olympus FE-320 Digital Camera
My 47 in. Samsung flat screen hd tv has a picture but its a little dark then goes in and out of blue to green to red. It gets a good picture though. And the channel numbers blend together when I flip the...
Hello, I'm sorry to yell you that the lcd display (screen) is bad. Usually one side looks close to normal, and the other is dark and the picture drags and looks smeared. The cost to replace the lcd display is more than you can buy another set for, sorry. thanks, Terry
Oct 13, 2012 | Televison & Video
I WANT DRIVER SOFT WARE FREE DOWN LOAD FOR MY VGA
Go to google and google any drivers you need; you should be able to download them.
Feb 02, 2011 | Toshiba Toahiba Satellite A60 A65 Series...
I can't install office 2007 in my TOSHIBA E A60
Go to control panel / Programmes & features and remove or uninstall the previous versions of office and then reboot the computer and then try to install the office.
Dec 19, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
For a few weeks my picture will go slow motioned looking and everything will have trails but would only last for a few min but now it is going on for hours...symptoms are slow motion picture with every...
It might not be from your tv but from your tv router which can't receive a good signal. I recommend you try unplugging your tv router and see if the other free channels are clearer than with the tv router plugged in.If they are clearer, then their is a problem with your router.You should call your tv company and tell them about it.Hope this helped your problem!
May 31, 2010 | Samsung LN-T3253H 32 in. LCD Television
Sound
1. There's been a problem when you either load a program or utilize another audio software, it will shut off the audio in the properties, or your driver got corrupt and needs reloading. These have been two of the issues I've had and fixed. Good luck.
Apr 19, 2009 | Toshiba Toahiba Satellite A60 A65 Series...
I have a carpet washer model 1698-m and i have a spare part L05-A50. I have the broken part but don't know where to replace the new one.
L05-A50 is not a Bissell part number, Here is a picture, let me know the number on the drawing, maybe I can help if you can't figure it out.
Mar 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
174 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
