Question about Vacuums
Kenmore vacuum model 116.29229
The powermate wont start. i checked the belt and i pushed the reset button
reddevil6
  • 1673 Answers
SOURCE: Kenmore Powermate Canister Vacuum Cleaner
Depending on which model, there is a couple of scres on the bottom, then on each side and back are release catchs that you pry up to release the top, then you can get to the belt. The other model you take off the light cover, it just snaps in place, then you can take out 2 screws from the top, on each side there is a slot, put a screwdriver up into the slot and pry out to release the tabs, then the cover comes off and you can get to the belt.
Posted on Feb 11, 2008
advacak
  • 125 Answers
SOURCE: I am trying to disassemble
Squeeze the sides of the lamp cover, and it will snap off. then you will see 2 screws under where it was the rest is obvious
Posted on Feb 06, 2009
SOURCE: Kenmore Model 116 PowerMate Jr stopped working
If the roller brush is not spinning freely once you remove it from the Power Mate Jr., then I have discovered the solution! There are end caps at each end of the roller brush. They seem to be permanently attached, but they are not. There is an axle inside the roller that is permanently attached to one of the caps. Take two pairs of pliers, and grab each end cap with a pair of pliers. Then pull hard to take them off. Once they are off, you will find that there is a big glob of hair wrapped around the axle inside. Remove the hair. Then reassemble the brush by putting the end caps back on. Make sure, when you put the caps back, that they are aligned so that they will fit back into the slots on the Power Mate Jr. You have to push hard to get the caps back on, maybe tapping one of them with pliers.
Posted on Mar 28, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
Posted on Dec 05, 2009
SOURCE: The Brush Motor on my Bissell Healthyhome Vacuum wont start
I had this same problem. There is a screw that holds the top handle and the lower handle "together". If this screw is not TOTALLY tightly screwed in, this will cause the contacts in the switch to BREAK contact, and therefore one or BOTH motors may not start, or cut in and out. This was the fix for me.
Posted on May 12, 2010
When vacuuming the belt stops turning
Your belt is probably stretched, replace it. Also check to be sure nothing is lodged in the brushes
Sep 03, 2012 | Panasonic Kenmore Canister Vacuum Hose 116...
I caught a shoestring in the brush and now it won't turn. I pressed the "overload protector reset" button but it's just loose and seems to have no effect.
Hi. I think it may still need resetting. Keep pushing reset. If this does not help remove the brush the turn it on. It should start. If so, there still may be somethng in the brush bearing that is stopping it from turning. It could also be that the belt broke when you got the lace. Let me know please, hope this helps. Chris
Feb 21, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
I by accident sucked up the corner of a sheet into the powermate of my vacuum. I turned the vacuum off and pulled out the sheet but now the powermate is no longer working (suction works fine) Is this...
These power heads have a kill switch on them. Not exactly clearly labeled.
the kill switch reset button should be on the right side of the unit as you look down like you are using it. you may want to try pushing it with the power to the power brush on. Upon resetting the button there, the power
head should start no problem.
Good luck with that.
Mark
Nov 12, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
My power head on my Kenmore canister sweeper dont work right.How do I get it apart and fix the problem?
Try pushing the reset button on the top of the power head first. There is a protection system on Kenmore canisters that protect the belt from breaking, and if something was vacuumed up into the head, it will cause this reset switch to activate to protect the belt. On the top of the power head look for the a small red button, or a grey button that says overload protection switch, and push down on it.
If the power nozzle lights are coming on, and the machine is making noise, then this means that the belt may be off inside the head, however if you're not getting any power, and the head light is not coming on, then this is probably a bad hose on the unit.
I have written a detailed repair on how to replace the belt on the Kenmore canisters on Fixya, just follow the link below. The only difference on the one I helped repair and yours may be the that the screws are actually located on the bottom of the power nozzle rather then underneath of the headlight cover. The other steps will be the same, just unscrew the screws on the bottom of the power head.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Please let me know if this didn't fix it, and I'll help you walk through this further and help you diagnosis the power head further.
Thanks,
Chris J.
GoVacuum.com
Apr 13, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
How to open a kenmore powermate vacuum to replace belt
You have to take the light cover off (push in at the bottom on each side) and there are two screws.
Some models have pressure locks on the back of the power nozzel cover. Just use a screw driver.
Jul 15, 2009 | Kenmore Canister Vacuum Vacuum
Need to check belt on a Kenmore WhisperTone powermate vacuum
There are two screws. Pry off the light bar on top by pushing against the sides, and you will see them inside just behind the light bulb.
Apr 04, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Restart button
Usually there is a red reset button to push on top of the power head, but some are on the back edge of the powerhead.
May 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
