Question about Car Audio & Video
No tail lights dash lights
Turn on headlights and taillights and dash lights dont come on but have brake and turn singals
  • matthew gonzales Dec 01, 2007
    i have the same problem in my 2003 grand am first the dash lights went out and now i don't have no power to the stereo i've checked all the fuses and i believe i hooked it up right according to the diagrams but it wont turn on anymore
  • 709 Answers
What is the year,make and mdel of your Vehicle. I could use this to help you determine a solution. All I can say right now , is that if you just installed the head unit, you must have pulled something loose under the dash. If I know the information, I can research a little to determine the cause.
Posted on Oct 10, 2007
Headlights work but not taillights what is the cause and how do i fix it?
First you need to determine if all lights in the back are out or just brakes lights or tail lights. Check fuses, taillights will have their own fuses. Could be a bad dash switch, which would be evident if brake lights work but not taillights.
Aug 25, 2015 | Cars & Trucks
Why do I have brake lights but no Tail light when the lights are turned on? put in new bulbs..
It is fairly common on US cars for the taillights and dash to be on the same fuse. This is apparently planned so you would know when you taillights are out. (the manual does not tell you that) If you have a owners manual, find the taillight fuse and it is probably blown.
Jun 12, 2014 | 2006 Chrysler 300
No brake or tail lights
Here is some information to consider and check. You should concentrate on the taillights first since that does not require you to constantly step on the brake pedal.
The bulb outage module, or lamp outage module, is located to the left of the drivers left leg while sitting in the seat. It is just slightly up under the dash, clipped into a black housing. It should be a white colored box with one large electrical plug with many wires plugging into it.
The switch above the brake light switch should be a cruise control deactivation switch, so that the cruise control turns off when the brake pedal is pressed.
Apr 30, 2009 | 1999 Mercury Cougar
99 chevy auto lamp problem
WHAT YOU MIGHT CHECK IS THE FUSE FOR TAILLIGHTS, OR DASH LIGHTS. THEY WORK OFF THE SAME FUSE. IF THE FUSE IS BLOWN THE HEADLIGHTS WORK BUT NO TAIL OR DASH LIGHTS
Feb 16, 2009 | 1999 Chevrolet Silverado 1500
Tail lights dont work but bake and turn singals do
did you also check the fuses under the hood, there is a 20 amp out there that feeds that circuit.
Feb 02, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Have headlights but no taillights
Put in a radio lately? - you'll probably find that the fuse is blown for the dash lights; and the stereo is wired incorrectly - if no radio - then there is a control module that controls the lighting I think - put in fog lamps either? I'd bet it was either fog lights or radio incorrectly installed, or control unit. You'll find that the dash lights and tail lights are usually connected (on same circuit). Be sure to turn the key "on" and check both sides of all fuses with a test light. If that turns up nothing, then a wiring diagram and some time are required....
Feb 01, 2009 | 1990 Honda Accord
Chevy k10 headlight/taillight problem
the fuses are located on the left side of the drivers foot well. these trucks have problems with rot and when they start to fall apart the beds move around and short out the taillights and youll usually lose the dash lights with the tails but the headlights are separate.
Jan 20, 2009 | 1984 Chevrolet Chevy
Head lights and tail lights don't work
Fuse, should be labled taillights in the fusebox under the driverside dash..
Dec 27, 2008 | 1985 Chevrolet Chevy
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
