PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Faulty HP Laptop
By chiefchog on May 07, 2009
HP Pavillion DV5000 laptop. Wont boot XP. Tried reinstalling windows, crashed at format stage. Dead HDD? Tried installing windows on external drive, no problem. Until first Win XP logo then blue screen. Bootable CDrom distribution of Linux (Slax) worked fine so assuming other components are fine.
Help appreciated.
Thanks.
Comments:
May 07, 2009
- Thanks everyone.
The drive is IDE so is the slipstreaming of sata drivers necessary?
Things have taken an interesting turn... Setup is currently copying files... 82%...
May 07, 2009
- Hmmm it all went fine... Restarted... Now...
Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\ntoskrnl.exe
Please re-install a copy of the above file.
Clarification Request
Posted by jkpf on May 07, 2009
you might want to try formatting the drive using the slax linux to see if the hdd has any problem during format
Solution #1
posted on May 07, 2009
Somewhat Helpful)
the_fire
Rank: Guru
Rating: 85%, 231 votes
Download the sata drivers for the laptop and slipstream the sata drivers with the xp installation disc ( making it bootable ) using nlite ( http://www.nliteos.com ) and then try and install - the other option is to disable AHCI in the bios or to make sure that it treats the hard drive in IDE mode and try and install xp.
If that does not help then post back and let me know.
The other option before you install xp is to go into recovery console and see if you can run chkdsk /r and see if that has any issues with the hard drive if it detects the hard drive.
If it does and you see any issues then if it cant fix them then there is something wrong with the hard drive possibly in which case download and burn the iso disc image from the hard drive manufacturers website ( diagnostic utility for the hard drive ) and run that and see if it reports any issues with the the hard drive. If that does not then it is obviously either a setting in the bios or because you have not got the SATA drivers intergrated with the xp disc.
Also if you can post back with a link to a photo of the Blue Screen of Death or post back exactly what it says.
Comments:
May 07, 2009
- no seeing as the drive is IDE you dont need the sata drivers - its just a common issue.
When you do a format in windows if you do a full format that will indicate any issues as well.
Since it is installing fine now it should be fine unless there were any scratches / finger prints / marks on the cd ?
May 07, 2009
- Note: The following notes assume an XP environment. The steps are similar for both 2000 and 2003 environments, but I did not take the time to investigate if there are any differences here.
Boot to the recovery console.
  • Turn on the computer, pop in the Windows XP CD.
  • Reboot the computer. If the Windows XP CD does not boot up, then reboot, go into the BIOS and configure the "boot order" to boot from CD first. Lather, rinse, repeat.
  • Select R for Recovery.
After getting to the Recovery Console prompt, make certain that you are in the C:\Windows path for XP (assuming that XP is on C:, that Windows was installed into the \Windows directory, and that your hard disk is readable).
Change to your CD drive - by typing "D:", "E:" or "F:" etc. -- this varies per system but is most often:
D: Change to i386 path by typing:
cd i386 Copy necessary files to root path (C: in this case) of winxp installation by typing:
copy ntldr C:
copy ntdetect.com C: Change back to your windows path:
C:
cd windows Attempt to fix the boot record:
fixboot c: Try restarting machine - if still nothing - go back into recovery console by booting from cd Then run:
fixmbr c: If it does work but you are getting an annoying boot.ini message everytime you restart your PC now go back into recovery console as above and run:
bootcfg /? Reference the below articles for more information on bootcfg. Be certain to select c:\windows as the boot installation.
Microsoft bootcfg pages:
May 07, 2009
- Cause:
1. Keyboard issue
2. Miscellaneous corruption
3. Corrupt boot.ini file.
4. Missing boot.ini file.
5. Missing or corrupt ntoskrnl.exe file.
6. Windows NT installed on a partition bigger then 7.8GB
7. Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
2. In the setup menu, type R to start the repair.
3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
4. Select the operating system you wish to fix, and then enter the administrator password.
5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
5. Once at the recovery console type chkdsk /r
6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
-krissyafc
-http://hybridtube.110mb.com/articles/
Was this helpful?
Yes
No
Solution #2
Not Rated)
tunmun
Rank: Wiz
Rating: 80%, 287 votes
try installing xp with third party raid driver
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
what are the best upgrades for acer travelmate 4200
Answer
How to apply this layout on my account?
Answer
football manager 2010 not loading. nothing coming on screen to run/set up program any ideas?
Answer
Ihave a dell 510 that has a dvd burner feature and I have tried to use dvd w disks but can/t seem to... (More)
Answer
everything including my desktp looks like digitalized and pixels... what's normally white is now a... (More)
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , PA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
