Question about AT&T 2230 Cordless Phone
Extension in use display on e5860 - AT&T 2230 Cordless Phone
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
The display went out on my lucent phone
If the extension still works then the LCD display has gone out. Replace the phone. If the extension doesn't work then move the extension wiring to a different port on the system. This will tell you if the port has gone bad.
May 22, 2014 | Avaya 700340193 Corded Phone
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
We have lucent phones and have know ideal of how to transfer or use intercom
To use both the transfer and the intercom it,s necessary to know the extension numbers of the phones your trying to call or transfer to. To find out what the extension number is on those extensions either press feature 00 (if the extension has a display) the extension number will be displayed on the screen, if the set doesn't have a display then you can use the intercom to call a extension that does have a display. To use the intercom press one of the intercom keys below the first two line keys and enter in the extension number of the persons phone you wish to call. To transfer a call, while talking to the caller press the Transfr key(above the hold key) then the extension number of the of the persons phone you wish to call then hang up.
Oct 14, 2010 | Lucent PARTNER18 Corded Phone
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
How do I identify extensions, transfer calls, conference call, change time.
To identify the extensions: if its a display set, press feature 00 and the screen will show the extension number. press feature 00 to exit programming.
If its a non-display set access the intercom and call a display set.The extension number will be displayed on the screen that is recieving the call.
To transfer a call: while your on the call to be transfered, press the transfer button and then the extension number of the person you wish to transfer the call toand hang up.
For a conference call:while on the line with the first caller,press the conf key (the caller will be placed on hold) place a call to your second party when they answer press the conf key again. all 3 parties will be bridged(you + the 2 lines) to get rid of one of the callers press thier line and feature 6 (conference drop)
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Jan 05, 2010 | AT&T Lucent MLS-12D Phone
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
Trying to add new phones to system
If you plug the phone in and it comes up with a display, then it has an extension.
To find the extension number of the phone, press Feature * 0, the display will say "Inspect" Now just press one of the intercom buttons. It will display the extension number. When done hit end.
Oct 27, 2008 | NorStar Meridian M7310 Phone
Programming handset
Put extension phone on base unit; press menu; press 0 0; press and hold intercom until charging light starts flashing. the display should show OK on the display screen of the extension phone; press OK. If you have more than one extension to add:
after you press 00; the symbol for # # # will come up. Enter a number for that extension i.e. 2; 3; or your choice.OK will come up on display at bottom right of display; press ok. hope this helps. This info should come on the extension phone and "menu" is on ext. unit. So turn the display up so you can see it while it is on base unit.
Jan 15, 2008 | Panasonic KX-TG5632 Phone
AT&T 2230 Cordless Phone Logo
32 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
