Question about Dayton Heating & Cooling
Dayton 4e461 product description
2YV14 need to find a new replacement fan blade and hub for a dayton wall heater model #2YV14
Hello Jeffrey Messenger,
Dayton is a big name product available at GRAINGER.
Electric Wall Furnace,
Recessed or Surface, 240VAC, Watts 9200
Replacement Parts
H
elp finding replacement parts?
Please call 1-800-GRAINGER
(1-800-472-4643)
The 2yv14 is a well known heater... sadly it has been
MANY years since I have purchased any
Dayton equipment... but GRAINGER RETAIL
OUTLETS WERE The reliable PLACE TO GO.
(see below).
GRAINGER
https://www.grainger.com/category/dayton/ecatalog/N-1z13ntg
DAYTON-Electric-Wall-Furnace-2YV14
Electric Wall Furnace Recessed or Surface 240VAC Watts 9200
Carnac the Magnificent
Mar 22, 2017 | Dayton Heating & Cooling
90000 btu high intensity infrared ceiling hung heat. Have replace twice and Honeywell gas valve once. Always starts and runs first time then never starts again. Coils on gas valve keep burning up. ??
Dayton 3E134E Troubleshooting guide - manualzz.com
manualzz.com/doc/1285710/dayton-3e134e-troubleshooting-guide
This heater must be installed and serviced by trained gas installation and service ... Dayton High-Intensity Heaters ® Description Dayton high-intensity heaters ... ofinfrared radiation by heating a ceramic refractory material to incandescence. ..... 3E133, 3E461, 5VD63, 5VD64 90,000 BTU/H Do not mount heater horizontally.
[PDF]Fall Heating - Plumbing & HVAC
plumbingandhvac.ca/images/documents/PHVAC_Sept-Oct03.pdf
Nova Scotia gas utility eyes dealer network ... valve underbody and screw trim pieces ... Infrared requires a different way of ... gives you a crisp picture, and speeds up pipe locating. ... tiative will keep HVAC contractors busy ..... labelling for equipment usinghigh pressure R410A ..... Multi fired from 90,000 to 179,000 btu/h.
Jan 05, 2016 | Dryers
What the codes
You want delay fuse instead of fast-acting fuse. Look for delay on product description.
Since the motor has a high amp draw when first starting, then that means surge of heat traveling over wire.
Fuse trips when sensing heat.
Delay fuse will accept high heat for longer period of time before tripping.
You have 1 Hp 6K321 motor from WW Grainger. You can contact grainger.
http://www.grainger.com/Grainger/DAYTON-General-Purpose-Motor-6K321?Pid=search
I recommend that you use 12 gauge wire and 20 amp fuse. Over-sizing wire will save heat loss and prevent damage to motor, and heat damage fuse box.
If you use smaller 14 gauge wire and 15 amp fuse, the motor will heat the wire, especially if length of wire is longer than 100 feet from fuse.
The motor has thermal protection, so motor is not overheating.
The wire is overheating.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Sep 27, 2012 | Dryers
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
Need wiring Diagram for a 3hp motor model #5K967M made by Dayton
Dayton is a product of Grainger Industrial supply. You can contact Product Information and Parts Help at 800-323-0620 or their Tech Service Dept at 888-361-8649. I'm sure they can help you. Just have the Model Number and Serial Number available.
Mar 08, 2011 | Dayton Heating & Cooling
Trying to find a replacement fan motor for a dayton electric garage heater moodel number 3e547 its around 12 years old
Go to grainger supply.com then go to dayton heaters with your model number and part number if you can find it,along with description of parts you need. I have been dealing with them for years and they are the main distributor for dayton furnaces.
They carry a large selection of parts and generally ship within two days. Hope this helps you. Thank you.
Jan 27, 2011 | Dayton Electric Heater
Need parts for Dayton Ultra Portable Heater Model 1VNX6A I need a source for parts
I would cotact Grainger industrials supplies by callig 1-800-323-0620. Or e-mail at Grainger.com I have dealt with this company for 25 years and I've always been happy to do business with them. Hope this helps you. You will need name brand,part description,and part no. if possible.
Nov 18, 2010 | Dayton E48 Oil Filled Utility Heater
Dayton unit heater
Dayton heaters are a product sold by Grainger. Contact them for a manual.
Aug 26, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
